Scott D 69 Posted June 29, 2022 Posted June 29, 2022 I'm not sure if this is a ROKU issue, or a server issue. Recently I have been having great difficulty on playing back OTA recordings that are created using Emby. If I play the created file using VLC on the recording PC, playback is fine. However, when trying to playback using Emby and a ROKU app (both on a media player and also on a ROKU TV). Here is some background: Server is running on a Windows 10 Home platform i3-4130 64 bit with 8 Gb of memory Temp folders and server software are located on a 500 Gb SSD drive. Emby is running version 4.7.5.0 Device used for this session to playback is a Hisense Roku TV that reports Roku SG 4.0.55 Here are the steps taken: Recording was made using Emby and an HDHomeRun Quatro Model HDHR5-4US with Firmware 20220203 on May 17th. Playback was started. Progress circle began to spin up to 34% and then stopped. After several minutes of not starting, user exited out of Emby. Please see attached files for log information. If this is a ROKU issue, please move to appropriate forum. ffmpeg-transcode-0505b446-060e-460a-8f7c-ab90dd05a3b0_1.txt ffmpeg-transcode-882a852c-4eda-4070-b2ba-0c8a8a7b2beb_1.txt ffmpeg-transcode-4148ca28-0b29-416c-81c0-f40e99002f9e_1.txt ffmpeg-transcode-528409fe-726a-43c6-bba1-b565daa7b00b_1.txt ffmpeg-transcode-b4f079e3-9e8c-4490-ad75-4865126658db_1.txt ffmpeg-transcode-b3419280-cf72-4790-a55a-6e12bee9dbec_1.txt ffmpeg-transcode-d57c5ff9-b48d-4dd1-ac35-1ebfaae55af4_1.txt ffmpeg-transcode-e6348f3e-1601-41be-8eef-c8c85b547343_1.txt ffmpeg-transcode-e971767d-2388-48cd-a0c7-67b00c0d7016_1.txt ffmpeg-transcode-e5782076-af76-4a81-9735-dc088ee5a99c_1.txt hardware_detection-63792115075.txt embyserver-63792115741.txt ffmpeg-transcode-0a014787-5735-4016-8c93-d90e280283c6_1.txt ffmpeg-transcode-3d1f3148-401d-4393-9a5f-603bcc18fdb7_1.txt ffmpeg-transcode-4a371890-9d3e-450f-8b4e-d2d2577045fd_1.txt ffmpeg-transcode-6b9136be-dba8-4e61-a216-6220979a6629_1.txt ffmpeg-transcode-9b82a82c-2d75-486c-baf4-47fbdabe7603_1.txt ffmpeg-transcode-9f9ce3de-255a-49b4-95ce-9c1654c6e969_1.txt ffmpeg-transcode-33cd6b16-e824-4888-bbb6-98f2528a763f_1.txt ffmpeg-transcode-34fd8e96-3a0f-44a6-84c2-a28227a73b31_1.txt ffmpeg-transcode-392aef96-d581-421c-831d-2c7cd08df52a_1.txt
speechles 2061 Posted June 30, 2022 Posted June 30, 2022 (edited) ffmpeg-transcode-34fd8e96-3a0f-44a6-84c2-a28227a73b31_1 16:03:43.396 [Closed caption Decoder @ 0000013bbacd2640] Data Ignored since exceeding screen width Last message repeated 5 times 16:03:43.427 [h264_qsv @ 0000013bbacda500] Error during encoding: device failed (-17) 16:03:43.427 Video encoding failed 16:03:43.444 Conversion failed! -> For this one, it seems the captions are rendering larger than the display area. It causes the encoder to panic. ffmpeg-transcode-392aef96-d581-421c-831d-2c7cd08df52a_1 16:05:03.612 Ignoring repeated subtitle frame Last message repeated 10674 times 16:05:03.830 [h264_qsv @ 00000155c80e7dc0] Error during encoding: device failed (-17) 16:05:03.830 Video encoding failed 16:05:03.849 Conversion failed! 16:05:03.849 -> For this one is appears the subtitles are repeated infinitely and the encoder panics. It is the EIA captions causing you grief. Edited June 30, 2022 by speechles
Scott D 69 Posted June 30, 2022 Author Posted June 30, 2022 Thanks for looking into this. It would appear that a recent change to Live TV has created issues. This had been working with no issue until just recently. I am using all of the same hardware for at least the last year. Recording has been scheduled through Emby. HDHomeRun firmware has not changed in a few months. Is there something that can be set or done to correct this problem on my end?
Scott D 69 Posted July 1, 2022 Author Posted July 1, 2022 Is it possible that the problem comes from the fact that this recording is at 60fps and being played back at only 30 fps? Is there a way to specify how recordings are made from HDHomeRun? I.e., 30 fps, 3 Mbps, or resolution. In watching the process of recording a show, I noticed the stream is opened up and then fed through ffmpeg to create the file. It would be nice to set some parameters as the recording is taking place.
Luke 42186 Posted July 5, 2022 Posted July 5, 2022 HI, are you still running into this? Were these recordings created using Emby Server 4.7.5?
Scott D 69 Posted July 5, 2022 Author Posted July 5, 2022 (edited) 15 hours ago, Luke said: HI, are you still running into this? Were these recordings created using Emby Server 4.7.5? Yes, the recording was created by scheduling an OTA series within Emby. Emby uses an HDHomeRun Connect Quatro with firmware 20220203. I will have to get back to you if the problem is still occurring as I have found a work around that prevents me from testing. Next scheduled record is this evening at 21:00. Playback will be attempted on Wednesday at some point during the day. Has something been changed, because it appears I am still running all the same stuff? 4.7.5, Roku 4.0.55, etc. Edited July 5, 2022 by Scott D
speechles 2061 Posted July 6, 2022 Posted July 6, 2022 (edited) Do you have the limit framerate enabled? By default this is set to No. But for lower performance Roku TV models this can be set to Yes. Is yours still set to No? Did you keep this setting set to Yes? Edited July 6, 2022 by speechles
speechles 2061 Posted July 6, 2022 Posted July 6, 2022 That option to limit the framerate will only appear on the Roku TV models. Since you mentioned you also played some back on a Roku TV I brought that one up. The other with allow direct streaming is what is important because it will not copy any Live TV streams set to No. It should be set to Yes until you experience problems.
Scott D 69 Posted July 6, 2022 Author Posted July 6, 2022 11 hours ago, speechles said: That option to limit the framerate will only appear on the Roku TV models. Since you mentioned you also played some back on a Roku TV I brought that one up. The other with allow direct streaming is what is important because it will not copy any Live TV streams set to No. It should be set to Yes until you experience problems. Thanks for the info. I will check with the family member with the Roku TV and make sure the setting is correct. 1
Scott D 69 Posted July 15, 2022 Author Posted July 15, 2022 Captured the problem and can reproduce at will. This has been going on for a few weeks and I have been able to work around by doing a conversion of the recorded files. That however is getting old very quickly. So here is the problem: TV show is recorded from an OTA broadcast using Emby 4.7.5.0 with an HDHomeRun Quatro receiver. The program is scheduled to record nightly and is doing as expected. The file is being added to a "Recordings" library as expected. Prior to this problem, the nfo and bif files were being created just after the show would complete. Playback was much like any other media file. Point, start, enjoy. Now, the program is being created as before. I can play the file using VLC with no issue. However, the bif file is no longer being created. If playback is attempted (either locally or outside the network) the video will play for less than a minute and then go to a spinning circle that will never get past 33%. As stated above, I have found that doing a conversion to the file will result in a playable program. Setup is the same as listed in the initial post. Playback device is Roku Streaming Stick+ running Roku SG 4.0.55 The attached log files are from a playback attempt made this morning. This is a fresh (reboot of entire computer system) log file and my test was the only connection and activity during the creation of the files. Playback was limited to 3 Mbps as this is the limit I have placed on all outside connections. I would post the media file, but it is 2.65Gb in size. ffmpeg-transcode-7df099f4-30e8-4346-8b85-d03aacae964d_1.txt ffmpeg-transcode-3b8ee361-1d99-47c4-965a-b9721f586be6_1.txt ffmpeg-transcode-b27f45f4-dcbf-48cb-8069-eae67a0d3a8f_1.txt hardware_detection-63793477597.txt embyserver-63793477831.txt ffmpeg-transcode-560bc378-bfc9-4285-a664-63d299c7e3ab_1.txt ffmpeg-transcode-1f3f1439-fe4d-483f-a7bf-4defb54d2039_1.txt MediaInfo.txt
Scott D 69 Posted July 15, 2022 Author Posted July 15, 2022 Possibly found that the problem is occurring on certain programs. It appears it may be an issue with the framerate. Attached is a MediaInfo for a file that was recorded using the same hardware/software setup. Different channel, different time but is playable without conversion and bif and nfo files were created as expected.Mediainfo.txtMediainfo.txtMediainfo.txt
Luke 42186 Posted August 3, 2022 Posted August 3, 2022 Hi, please try updating to Emby Server 4.7.6 and let us know if that helps. Thanks.
Scott D 69 Posted August 5, 2022 Author Posted August 5, 2022 Yes, the problem remains. Server at 4.7.6.0 and Roku using version 4.0.63.
