horstepipe 423 Posted June 29, 2022 Posted June 29, 2022 Hello On v2.0.77 I'm seeing a direct play problem for a file having a 7.1 eac3 track. I set my Amazon stick to "downmix to stereo" in Emby settings. The file doesn't start to play at all. If I enable transcoding it transcodes the audio because of "too much audio channels". I didn't notice that problem on the prior version of Emby. I sent inapp logs at 11:19 (Germany)
horstepipe 423 Posted June 29, 2022 Author Posted June 29, 2022 (edited) Audio settings on the Amazon stick itself were set to "PCM". If I set them to "Dolby Digital Plus" and in Emby set to "auto" it also works. But some people have older TVs / AVRs which do not support eac3 - so they need the option "downmix to stereo". Edited June 29, 2022 by horstepipe
ebr 16337 Posted June 29, 2022 Posted June 29, 2022 3 hours ago, horstepipe said: If I enable transcoding So that implies you've disabled transcoding on your server and, if you enable that, then our error fallback works correctly? 3 hours ago, horstepipe said: Audio settings on the Amazon stick itself were set to "PCM". If I set them to "Dolby Digital Plus" and in Emby set to "auto" it also works. Okay, so the audio setting on the device may be the root of the issue. Your log is full of invalid audio errors.
horstepipe 423 Posted June 29, 2022 Author Posted June 29, 2022 Basically yes, the fallback works but we had the same situation some months ago and it was fixed. The problem seems to have introduced again with v2.0.77.
horstepipe 423 Posted June 29, 2022 Author Posted June 29, 2022 So basically Emby is not able to decode eac3 7.1 track to Stereo by itself in the current version anymore.
horstepipe 423 Posted June 29, 2022 Author Posted June 29, 2022 I will try other movies with a 7.1 eac3 track to make sure that’s the problem.
ebr 16337 Posted June 29, 2022 Posted June 29, 2022 Can you try with the standard Android app on the same device? 1
horstepipe 423 Posted June 30, 2022 Author Posted June 30, 2022 It works there BUT there is no option to downmix to stereo in that app and my devices support eac3. So I need to visit my friend who reported that issue and test it there…
horstepipe 423 Posted June 30, 2022 Author Posted June 30, 2022 Tested 3 other movies with the Android TV / Fire OS app on the stick, all same behavior. eac3 5.1 works fine eac3 7.1 does not work if downmix to stereo is enabled.
ebr 16337 Posted June 30, 2022 Posted June 30, 2022 Okay, I think we've identified the issue. Thanks. 1
Luke 42245 Posted July 14, 2022 Posted July 14, 2022 We'll be getting a fix out for this. Thanks. 1 1
Luke 42245 Posted July 15, 2022 Posted July 15, 2022 HI, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
horstepipe 423 Posted July 16, 2022 Author Posted July 16, 2022 On 6/30/2022 at 10:47 AM, horstepipe said: It works there BUT there is no option to downmix to stereo in that app and my devices support eac3. So I need to visit my friend who reported that issue and test it there… 15 hours ago, Luke said: HI, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks ! ...
horstepipe 423 Posted July 16, 2022 Author Posted July 16, 2022 On 7/14/2022 at 8:20 PM, Luke said: We'll be getting a fix out for this. Thanks. I thought a fix was already coming...?
horstepipe 423 Posted August 19, 2022 Author Posted August 19, 2022 So what is the status of the issue now? Shall I tell my user to try it with the recent android tv beta?
Luke 42245 Posted August 19, 2022 Posted August 19, 2022 3 hours ago, horstepipe said: So what is the status of the issue now? Shall I tell my user to try it with the recent android tv beta? Or have them side load the standard app.
horstepipe 423 Posted August 19, 2022 Author Posted August 19, 2022 3 hours ago, Luke said: Or have them side load the standard app. Yes this works. But as you and ebr said you have a fix for that in place I‘m wondering… Did you think you have fixed it and later noticed you didn’t? Not a problem if this is the case but please inform about the status. Sideloading takes some time to bring the people to do it, as well as joining the beta program. Bur whatever, I will try both things with him if I am there next time. Best regards
ebr 16337 Posted August 19, 2022 Posted August 19, 2022 There should be another beta of the TV app in the next few days and you can see if that addresses this, or just use the standard one.
Solution horstepipe 423 Posted August 19, 2022 Author Solution Posted August 19, 2022 Hey I am there now and installed v.78, working there! thanks!
