greg1947 1 Posted June 29, 2022 Posted June 29, 2022 I have been trying for days to reestablish Emby Connect. I had it working,but have had multiple problems with hard drive failure's and then a router going,bad.. When I try to get emby connect to work, I sign in and reach a screen with two old servers that use my old IP address,that screen gives met the option to add a new server. When I do that it won't connect. I know the user name and password is correct.. Any idea whats going on here? is there a way to get rid of the old servers? TIA, Greg
Happy2Play 9812 Posted June 29, 2022 Posted June 29, 2022 There should be a menu option to remove/delete the server but believe this is client/app specific. Long click or actual menu option
Luke 42245 Posted June 29, 2022 Posted June 29, 2022 Hi, yes every Emby app has a function to delete servers from the server selection screen. Does this answer your question?
greg1947 1 Posted June 29, 2022 Author Posted June 29, 2022 I never seen those options with all the googling I did.. Thanks,I did manage to remove them. I'm still struggling trying to get emby connect to work.. I may be back with more questions.. 1
Bubbie 0 Posted January 7, 2023 Posted January 7, 2023 Why doesn't Emby just give us the option to completely delete dead servers from our account through Windows like Plex does? Why let these dead servers haunt our client apps forever.
Luke 42245 Posted January 7, 2023 Posted January 7, 2023 6 minutes ago, Bubbie said: Why doesn't Emby just give us the option to completely delete dead servers from our account through Windows like Plex does? Why let these dead servers haunt our client apps forever. Hi, we do. It's in all of our apps on the server selection screen.
