heula 192 Posted October 15, 2013 Posted October 15, 2013 I have a few issues with coverart. * When I sort my photos to the genre index my thumbs are being processed as it looks like the film treatment in ROC. My settings for photos are set to plaque for most items. * Im default theme these same items are not being processed at all. * When I sort it back to none all looks fine with the plaque treatment. This also shows the aspect ratio issue. * In my photos folder setup I use Year folders - month folders - photos. In some situations I have a subfolder in the month folder with for example my holiday photos in them. When this is the case then the month folder will not be processed at all.
ebr 16340 Posted October 15, 2013 Posted October 15, 2013 CoverArt does not process Photos by design so the things getting treatments must be resolving as something else (Folders maybe).
heula 192 Posted October 16, 2013 Author Posted October 16, 2013 CoverArt does not process Photos by design so the things getting treatments must be resolving as something else (Folders maybe). No, I don't mean the photo's but the year and month folders. When the index genre is choosen then the folders are being processed wrong. And some month folders that has subfolders and photosin them are not being processed at all.
Solution ebr 16340 Posted October 16, 2013 Solution Posted October 16, 2013 Indexing is broken in MBC due to a bug in the last server release so that is producing empty folders anyway. On the sub-sub folder, it looks like your "6 Juni" folder does not have an image associated with it. 1
heula 192 Posted October 16, 2013 Author Posted October 16, 2013 Indexing is broken in MBC due to a bug in the last server release so that is producing empty folders anyway. On the sub-sub folder, it looks like your "6 Juni" folder does not have an image associated with it. Yes you're right with this.
