averon 7 Posted June 26, 2022 Posted June 26, 2022 Hello, I am confused. I noticed emby has now skip intro, when browsing the plugins, I noticed there's also a plugin now. Can someone explain me, if its the same, or where the difference is? Side question, (I guess, I already know the answer, but anyway) Is it possible to use skip-intro feature while casting to embycon/chromecast? and if "no" would it be possible to skip the intro automatically triggered by emby server itself? Cheers
crusher11 1143 Posted June 26, 2022 Posted June 26, 2022 https://github.com/chefbennyj1/Emby.IntroSkip.Release/wiki/Feature-List-Plugin-vs-Core 1
rbjtech 5341 Posted June 26, 2022 Posted June 26, 2022 10 hours ago, averon said: Side question, (I guess, I already know the answer, but anyway) Is it possible to use skip-intro feature while casting to embycon/chromecast? and if "no" would it be possible to skip the intro automatically triggered by emby server itself? On the 2nd point - embycon is good but we have not had any users test Chromecast - Please let us know and we'll update the matrix below https://github.com/chefbennyj1/Emby.IntroSkip.Release/wiki/8.-Emby-Client-Compatibility-List
averon 7 Posted June 30, 2022 Author Posted June 30, 2022 On 6/26/2022 at 6:39 PM, rbjtech said: On the 2nd point - embycon is good but we have not had any users test Chromecast - Please let us know and we'll update the matrix below https://github.com/chefbennyj1/Emby.IntroSkip.Release/wiki/8.-Emby-Client-Compatibility-List Hello, not sure what I do wrong, but I can't get intro-skip plugin working with embycon on kodi. I have the plugin installed and it works with android client to skip intros I enabled auto-skip in the client, from where I control embycon I installed Kodi Companion on Emby server What do I miss?
rbjtech 5341 Posted July 1, 2022 Posted July 1, 2022 On 30/06/2022 at 09:26, averon said: Hello, not sure what I do wrong, but I can't get intro-skip plugin working with embycon on kodi. I have the plugin installed and it works with android client to skip intros I enabled auto-skip in the client, from where I control embycon I installed Kodi Companion on Emby server What do I miss? A good question - we got the info from other users that it worked, but just took their word for it I'm afraid - we do not run Kodi/Embcon ourselves. Maybe somebody who runs Kodi/embycon can help out here.. If it doesn't work (and needs a real emby client) then my apologies and I will remove it from the support list.
averon 7 Posted July 2, 2022 Author Posted July 2, 2022 8 hours ago, rbjtech said: A good question - we got the info from other users that it worked, but just took their word for it I'm afraid - we do not run Kodi/Embcon ourselves. Maybe somebody who runs Kodi/embycon can help out here.. If it doesn't work (and needs a real emby client) then my apologies and I will remove it from the support list. Well, I would love to get it to work. If you could ask those who said it worked, that would be awesome to figure out what I do wrong.
TeamB 2440 Posted July 2, 2022 Posted July 2, 2022 if you want someone to dig into this a little post over on the EmbyCon forum and I will see what I can find out.
TeamB 2440 Posted July 3, 2022 Posted July 3, 2022 https://emby.media/community/index.php?/forum/186-embycon/
