els 0 Posted June 26, 2022 Posted June 26, 2022 I reported the issue about two years and kind of abandon the idea of using Emby for Live TV. I still use Emby for movies and such and would like to revisit closed captioning with Live TV. This time I'll make an effort to provide logs and such. I have the following: HDHomeRun Connect 4K Emby Server version 4.7.2.0 Emby app for Android TV 2.0.70g I enabled Direct Play Live TV on Emby app but I do not see "Expose Closed Captions in live and recorded TV" option. I'm not sure if I should see that option. Also, I enabled direct play of TS streams for recorded shows. The CC icon does not show up on OSD when watching Live TV. The CC icon shows up on recorded TS however when I check the option (with und) a modal dialog appears indicating unable to load subtitle. I know Android TV does support CC and has been for couple years in fact it used to work until 2 years ago. Let me know if you require screenshots and log files. I'll make sure to provide details in a timely manner so we can get this resolved. Thanks. Ethan
ebr 16336 Posted June 26, 2022 Posted June 26, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Additionally, please follow the instructions to send a log from the app. Thanks.
els 0 Posted June 26, 2022 Author Posted June 26, 2022 I've sent logs from Emby app approximately 5-10 minutes from the time of this post. User name is Ethan. In addition, attached is the Emby server log. Let me know if you want some pictures of the Emby app such as Live TV settings. embyserver.txt
ebr 16336 Posted June 27, 2022 Posted June 27, 2022 Thanks for the logs. There is an issue in Exoplayer with certain types of closed captions where it just doesn't see them. We are trying to track it down. Thanks.
els 0 Posted June 27, 2022 Author Posted June 27, 2022 Thank you @ebr! Let me know if you need anything further from me.
justinrh 267 Posted June 27, 2022 Posted June 27, 2022 7 hours ago, ebr said: There is an issue in Exoplayer When did you know about this, @ebr?
ebr 16336 Posted June 27, 2022 Posted June 27, 2022 38 minutes ago, justinrh said: When did you know about this, @ebr? We've known for a while that Exo simply doesn't recognize some of these closed captions. We do not know yet why or exactly what it is about them that causes it.
els 0 Posted June 27, 2022 Author Posted June 27, 2022 I should mention at one point Emby app on Nvidia Shield Pro worked then stopped approximately two years ago. I don't know what had changed.
Luke 42243 Posted March 19, 2025 Posted March 19, 2025 Hi, can you please try this build and see how things compare? Thanks !
