bastionntb 20 Posted June 24, 2022 Posted June 24, 2022 Title. Noticed that the temp was folder getting larger. When does Emby delete those files? Is it time based; size based?
Happy2Play 9813 Posted June 24, 2022 Posted June 24, 2022 If they are not being cleaned up after a properly stopped playback session, then the only time the folder will be cleared is a Emby server restart as that is part of the startup routine.
Luke 42246 Posted June 25, 2022 Posted June 25, 2022 Hi there, can we please look at a specific example? Thanks.
