calvin_evird 5 Posted June 24, 2022 Posted June 24, 2022 Hi all, I noticed that my Synology NAS has Media Indexing (DSM7 I think?) in the control panel. Its swtiched off at the moment, does anyone know if switching it on will help performance for Emby? Or is it more to do with Synology media? I don't really use it for DLNA so its really only if its useful for emby or not. Cheers!
Solution Luke 42243 Posted June 25, 2022 Solution Posted June 25, 2022 HI, I don't think it will have any impact. Emby Server does not use it.
calvin_evird 5 Posted June 25, 2022 Author Posted June 25, 2022 Thanks Luke, that helps a lot. I think you're right!
