liamlovesyou 1 Posted June 30, 2022 Author Posted June 30, 2022 1 hour ago, ebr said: Same thing in your logs: 06-29 16:18:15.070 19681 19681 E EventLogger: Caused by: java.net.SocketTimeoutException: timeout There is no way, unfortunately, for us to determine why that occurred. Perhaps the version currently in Google review will make a difference since it does update Exoplayer. Alright, I'll keep an eye out for when that releases
liamlovesyou 1 Posted July 1, 2022 Author Posted July 1, 2022 I'm curious if this could be an issue with my motherboards Ethernet controller. I witnessed it pausing, then checked my task manager and it was sending 0 data, then spiked to 640mbps like it was buffering and the playback resumed.
ebr 16337 Posted July 1, 2022 Posted July 1, 2022 I suppose that's possible. All we can tell from the app side is that data stops coming in for too long.
Luke 42245 Posted July 4, 2022 Posted July 4, 2022 Hi, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
liamlovesyou 1 Posted July 4, 2022 Author Posted July 4, 2022 (edited) 4 hours ago, Luke said: Hi, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks ! Been playing a few episodes that I previously had issues with using the TV app, Android mobile app sideloaded hasn't had any issue yet Edit: just paused playback multiple times, will send logs Edited July 4, 2022 by liamlovesyou
Luke 42245 Posted July 5, 2022 Posted July 5, 2022 18 hours ago, liamlovesyou said: Been playing a few episodes that I previously had issues with using the TV app, Android mobile app sideloaded hasn't had any issue yet Edit: just paused playback multiple times, will send logs HI, yes let's look at an example of that. Thanks.
liamlovesyou 1 Posted July 5, 2022 Author Posted July 5, 2022 4 hours ago, Luke said: HI, yes let's look at an example of that. Thanks. How can I send logs from Android mobile app?
Luke 42245 Posted July 6, 2022 Posted July 6, 2022 19 hours ago, liamlovesyou said: How can I send logs from Android mobile app? Hi, can you please try this version of the android app: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide a log from the app by following these instructions: Thanks !
liamlovesyou 1 Posted July 6, 2022 Author Posted July 6, 2022 19 minutes ago, Luke said: Hi, can you please try this version of the android app: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide a log from the app by following these instructions: Thanks ! Do you want server logs or the android logs from the device?
ebr 16337 Posted July 6, 2022 Posted July 6, 2022 1 hour ago, liamlovesyou said: the android logs from the device? These. Thanks.
