Zero_Kool 5 Posted October 1, 2014 Posted October 1, 2014 Enviroment: Windows 7 box = running MB3 Xbox 360 = Windows Media Center + MB3 Classic Plugin. Issue: Size is off when viewing content. Not sure how to resize? Currently can Full Size the frame but it cuts off the edges. Not sure where adjustments are at? MB3 Classic Configuration or is it in the MB3 Server configuration? Many advance "thank you's" for replies.
Logos302 86 Posted October 1, 2014 Posted October 1, 2014 you might be talking about overscan, but I'm not sure, a picture would be helpful in show us the problem.
techywarrior 689 Posted October 1, 2014 Posted October 1, 2014 There are two different things depending. There is the overscan/underscan of WMC if everything is "framed wrong" or if it's just the video player in MBC then you can play with the under/over scan settings in the MBC settings (video player section). Also, you are asking about MBC but posted this in the MBT forum so I am moving it.
Solution ebr 16335 Posted October 1, 2014 Solution Posted October 1, 2014 From the KB: Media Browser Classic is not displayed on 100% of the screen. How to troubleshoot overscan issues. 1
Zero_Kool 5 Posted October 1, 2014 Author Posted October 1, 2014 Here the screen is off on the top Here are the options to resize when you play When selected to vertical stretch to prevent a larger blue border
Zero_Kool 5 Posted October 1, 2014 Author Posted October 1, 2014 I have a blue border how can this be fixed?
techywarrior 689 Posted October 1, 2014 Posted October 1, 2014 From the KB: Media Browser Classic is not displayed on 100% of the screen. How to troubleshoot overscan issues.
Zero_Kool 5 Posted October 1, 2014 Author Posted October 1, 2014 I tried those but not sure I am applying the fix correctly
techywarrior 689 Posted October 1, 2014 Posted October 1, 2014 The picture is really small but it looks like the WMC settings need to be adjusted. Look at the KB article and go down to the part that says "underscan"
Zero_Kool 5 Posted October 1, 2014 Author Posted October 1, 2014 Thanks but do you have to save the configure changes and restart for them to take effect?
techywarrior 689 Posted October 1, 2014 Posted October 1, 2014 well, you certainly would have to save them. Not sure if a restart is required. (I don't believe so) You should certainly try though.
