snader 1 Posted June 22, 2022 Posted June 22, 2022 since I have been using Emby server on my Raspberry Pi and the Android TV client on the nVidea Shield, I don't want anything else. The only negative I can think of is the use of the subtitle interface. As can be seen in the screenshots, I cannot select subtitles when I come from the TVshows overview, but I can when I target an episode. It would be nice if I can always select the subtitels for the upcoming episode... or when pausing an episode, to turn on the subtitles there instead of going back to the main screen first.
Solution GrimReaper 4898 Posted June 22, 2022 Solution Posted June 22, 2022 (edited) 15 minutes ago, snader said: I cannot select subtitles when I come from the TVshows overview, but I can when I target an episode. Of course you cannot (in any client app) as subs can differ per episode - and some episodes don't even have to have it - how would you preselect that on Series level? 15 minutes ago, snader said: It would be nice if I can always select the subtitels for the upcoming episode... There are various subtitle modes (Forced, Default, Smart, Always show) for each user in settings for exactly that purpose, so desired subs can be automatically pre-selected. 15 minutes ago, snader said: when pausing an episode, to turn on the subtitles there instead of going back to the main screen first. Sure you can do that, bring up OSD while paused or playback (press Down on remote), select "CC" icon. Edited June 22, 2022 by GrimReaper Typo 1 1
snader 1 Posted June 22, 2022 Author Posted June 22, 2022 Thank you very much. The 'push down' while playing is new to me.. works perfectly. 1
Sparker 44 Posted June 28, 2022 Posted June 28, 2022 You can also set a preference in the player settings to behave the same for most files where subtitles are present. So if your subtitle language preference is Dutch and you set subtitles to Smart, it should automatically load Dutch subtitles with English audio tracks. I'm a bit hard of hearing so I always have subtitles showing, and I moved to Emby because it handles subtitles far better than Plex can with some 1080p and 4K media.
