Happy2Play 9800 Posted June 21, 2022 Posted June 21, 2022 Devs will have to comment more but TVDB and FanArt have issues with your connection. System.Net.Http.HttpRequestException: An attempt was made to access a socket in a way forbidden by its access permissions. (api4.thetvdb.com:443) System.Net.Http.HttpRequestException: An attempt was made to access a socket in a way forbidden by its access permissions. (assets.fanart.tv:80) But appear to have no issues with TMDB or OMDB.
Luke 42186 Posted June 21, 2022 Posted June 21, 2022 Hi, they seem to be working OK for me right now. In your case though, it's hard to say. From Emby Server's perspective it knows it can't reach fanart.tv's images, but it can't always determine if it's due to something blocking the connection on your end, or if fanart is just having intermittent problems (which they sometimes do). So it could be something on the fanart side, but it could also be something network/VPN/security software related on your end.
Luke 42186 Posted June 21, 2022 Posted June 21, 2022 OK so if it's happening with tvdb as well then you probably have something interfering with Emby Server's ability to send these outgoing requests.
Solution Waldoo 14 Posted June 21, 2022 Author Solution Posted June 21, 2022 @Luke it was my vpn so sorry
Luke 42186 Posted June 21, 2022 Posted June 21, 2022 1 minute ago, Waldoo said: @Luke it was my vpn so sorry Thanks for the feedback.
Waldoo 14 Posted June 22, 2022 Author Posted June 22, 2022 @Luke what besides emby server to exclude from the tunnel? Id like to use my vpn with emby
Luke 42186 Posted June 22, 2022 Posted June 22, 2022 9 minutes ago, Waldoo said: @Luke what besides emby server to exclude from the tunnel? Id like to use my vpn with emby That's it, but if you find the exclusion doesn't work, it might be due to limitations of how the exclusion is done: https://github.com/dotnet/runtime/issues/47267#issuecomment-764624449
Waldoo 14 Posted June 22, 2022 Author Posted June 22, 2022 @Luke second time reading it how do that fix my problem?
Luke 42186 Posted June 22, 2022 Posted June 22, 2022 4 minutes ago, Waldoo said: @Luke second time reading it how do that fix my problem? It may not. I'm just explaining that if you have trouble with the VPN bypass, that might be why.
Waldoo 14 Posted June 22, 2022 Author Posted June 22, 2022 @Luke I dont it why fanart works on plex with vpn on? but broken in emby
Luke 42186 Posted June 22, 2022 Posted June 22, 2022 Possibly due to the issue I linked above if you are trying to configure VPN bypass.
Waldoo 14 Posted June 22, 2022 Author Posted June 22, 2022 @Luke I think there is something wrong with your program if it works in plex with a vpn on with fanart.tv then it should work with emby I tried doing a route too using this guide https://support.hidemyass.com/hc/en-us/articles/202720646-How-to-let-websites-and-IPs-bypass-the-VPN-using-static-routing did not do anything. If you cant fix the problem can i get a refund?
Luke 42186 Posted July 2, 2022 Posted July 2, 2022 HI there, were you able to figure out fanart with the VPN?
Waldoo 14 Posted July 3, 2022 Author Posted July 3, 2022 No, I just used a docker image on my NAS to solve my issue . Could not get it working on windows.
