Waldoo 14 Posted June 21, 2022 Posted June 21, 2022 (edited) ??? embyserver (6).txt Edited June 21, 2022 by Waldoo
Happy2Play 9811 Posted June 21, 2022 Posted June 21, 2022 Sorry but need all corresponding information. Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! I can assume these are items that do not Direct Play as Apple does require special attention vs all other platforms.
Happy2Play 9811 Posted June 21, 2022 Posted June 21, 2022 Sorry didn't see you edited your post. Can you post the ffmpeg log.
Waldoo 14 Posted June 21, 2022 Author Posted June 21, 2022 sure ffmpeg-remux-f229c77b-b0d7-4c90-88fc-847298c3e967_1.txt ffmpeg-remux-4796879c-2062-42a5-b7a2-90c2810060c0_1.txt ffmpeg-remux-cf0b4927-b039-435d-bf76-af525de05359_1.txt
Waldoo 14 Posted June 21, 2022 Author Posted June 21, 2022 Is fan art down its not loading images from there for me
vdatanet 1619 Posted June 21, 2022 Posted June 21, 2022 (edited) This is a well known (and ignored) issue. Since HLS fMP4 was introduced, using MPV player, remuxing (if audio is no supported) is broken. Edited June 21, 2022 by vdatanet
Waldoo 14 Posted June 21, 2022 Author Posted June 21, 2022 2 minutes ago, vdatanet said: This is a well known (and ignored) issue. Since HLS fMP4 was introduced, using MPV player, remuxing (if audio is no supported) is broken. So its the audio?
vdatanet 1619 Posted June 21, 2022 Posted June 21, 2022 1 minute ago, Waldoo said: So its the audio? Yes
Happy2Play 9811 Posted June 21, 2022 Posted June 21, 2022 If you changed audio tracks to something beside TrueHD do you get the same results?
Happy2Play 9811 Posted June 21, 2022 Posted June 21, 2022 7 minutes ago, Waldoo said: Is fan art down its not loading images from there for me Not that I am aware of but you have a few errors but overall are getting images from fanArt per your log. 2022-06-21 16:06:05.619 Error HttpClient: Error getting response from http://assets.fanart.tv/fanart/movies/624860/movieposter/the-matrix-resurrections-6196a7f302a39.jpg *** Error Report *** Version: 4.7.4.0 Command line: C:\Users\looot\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.22000 Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: C:/Users/looot/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 16 Data path: C:\Users\looot\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\looot\AppData\Roaming\Emby-Server\system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: An attempt was made to access a socket in a way forbidden by its access permissions. (assets.fanart.tv:80) ---> System.Net.Sockets.SocketException (10013): An attempt was made to access a socket in a way forbidden by its access permissions. at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request) at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.GetHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) Source: System.Net.Http TargetSite: Void MoveNext() InnerException: System.Net.Sockets.SocketException: An attempt was made to access a socket in a way forbidden by its access permissions. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
Waldoo 14 Posted June 21, 2022 Author Posted June 21, 2022 try another hdr10 with ac3 5.1 black screen
Happy2Play 9811 Posted June 21, 2022 Posted June 21, 2022 1 minute ago, Waldoo said: thats all there is Sorry but all the logs you posted have multiple audio tracks.
Happy2Play 9811 Posted June 21, 2022 Posted June 21, 2022 Just now, Waldoo said: try another hdr10 with ac3 5.1 black screen Is there a ffmpeg log for that playback?
Waldoo 14 Posted June 21, 2022 Author Posted June 21, 2022 ffmpeg-directstream-dc68da59-5146-41c5-a0a3-81abd46df770_1.txt
vdatanet 1619 Posted June 21, 2022 Posted June 21, 2022 2 minutes ago, Waldoo said: ffmpeg-directstream-dc68da59-5146-41c5-a0a3-81abd46df770_1.txt 191.96 kB · 1 download It's direct streaming. It only works with direct play. directstream and remuxing is broken.
vdatanet 1619 Posted June 21, 2022 Posted June 21, 2022 You gen direct play only if all the tracks are AC3, if any of them is not supported, in the supported ones we have direct streaming and in the unsupported ones remux.
vdatanet 1619 Posted June 21, 2022 Posted June 21, 2022 @Waldoo Can you try it with any movie that only has AC3 tracks?
vdatanet 1619 Posted June 21, 2022 Posted June 21, 2022 1 minute ago, Waldoo said: but i am direct playing direct stream is not direct playing, streams are not altered but are repackaged using HLS. In short, the MPV player has not been usable for quite some time.
Waldoo 14 Posted June 21, 2022 Author Posted June 21, 2022 (edited) mpv what is that Edited June 21, 2022 by Waldoo
