plittlefield 56 Posted June 20, 2022 Posted June 20, 2022 (edited) I apologise if my terminology is a little off for this, but basically … I used to be able to pause a movie or show, then hold down the right arrow on the Roku remote to fast forward skip to a point in the video quickly. This now does not work. I can skip forward on pause BUT I have to keep letting go of the button on the remote and then press it in again which skips forward only 10 seconds. It was better before where it would skip faster and faster when you held the remote control button down. Am I missing where this is now? Edited June 20, 2022 by plittlefield
plittlefield 56 Posted June 21, 2022 Author Posted June 21, 2022 Ah, so after much reading (yeah should have just jumped down to the bottom of the post) you now have to use the fast forward button [ »] next to play/pause... which does make sense. I shall try this tonight Thanks.
ebr 16334 Posted June 21, 2022 Posted June 21, 2022 We will be looking to also support holding the arrows down but, at this time, the ff/rew will work. Thanks.
plittlefield 56 Posted June 21, 2022 Author Posted June 21, 2022 Yes, I can confirm the Fast Forward works a treat. Keep that! The left and right arrows on the remote for a 10 second jump in either direction is fine too. Keep that! Thanks for putting me in the “right” direction (see what I did there?) Paully 1
