Happy2Play 9811 Posted November 2, 2022 Posted November 2, 2022 @CarlosLima look at the change as I changed the code.
Guest Posted November 2, 2022 Posted November 2, 2022 (edited) Oops, I ran a new clean in the browser and in cloudflare and now the links are visible. I think it was late to update this time. I'm sorry. And now it is also possible to click on the links. I believe everything is perfect now. No words to thank you for your patience and commitment. Thank you very much. Edited November 2, 2022 by CarlosLima
Happy2Play 9811 Posted November 2, 2022 Posted November 2, 2022 (edited) 5 minutes ago, CarlosLima said: Oops, I ran a new clean in the browser and in cloudflare and now the links are visible. I think it was late to update this time. I'm sorry. If you are talking about header being larger while scrolling you have to change this @media (min-width: 100em) { div.headerTop-withSectionTabs:not(.skinHeader-tv) { height: calc(3.71em + max(1.2em,env(safe-area-inset-top,0))); }} To the edit code as mentioned, added scrolling and adjusted min-width slightly @media (min-width: 80em) { div.headerTop-withSectionTabs:not(.skinHeader-tv), div.headerTop-withSectionTabs.headroom-scrolling:not(.skinHeader-tv) { height: calc(3.71em + max(1.2em,env(safe-area-inset-top,0))); }} Edited November 2, 2022 by Happy2Play
Guest Posted November 2, 2022 Posted November 2, 2022 I changed your last statement. Now everything perfect. Thank you so much again. You are the best.
Alexwerilles 3 Posted November 10, 2022 Posted November 10, 2022 On 6/20/2022 at 7:51 PM, Happy2Play said: Easiest would be adding "flex-direction-column" back to "emby-scroller"also fixed the margin as that was broken/unused the previous way written. Reveal hidden contents <div class="view flex flex-direction-column withTabs"> <div class="tabContent flex flex-grow" data-index="0"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-direction-column flex-grow focuscontainer-down" data-bindheader="true"> <div class="Personal-Links" style="top:120px;text-align:center;position:relative;"> <a is="emby-linkbutton" class="button-link" href="LINK#1" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0 .7em;">TEXT1</a>  <a is="emby-linkbutton" class="button-link" href="LINK#2" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0 .7em;">TEXT2</a>  <a is="emby-linkbutton" class="button-link" href="LINK#3" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0 .7em;">TEXT3</a>  <a is="emby-linkbutton" class="button-link" href="LINK#4" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0 .7em;">TEXT4</a>  <a is="emby-linkbutton" class="button-link" href="LINK#5" target="_blank" style="text-decoration: none;color: #D3D3D3;margin: 0 .7em;">TEXT5</a>  <pre> </pre> </div> <div class="scrollSlider flex-grow padded-top-page"> <div class="sections"></div> <div class="padded-bottom-page"></div> </div> </div> </div> <div class="tabContent flex flex-grow" data-index="1"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-grow focuscontainer-down" data-bindheader="true"> <div class="scrollSlider flex-grow padded-top-page"> <div class="sections"></div> <div class="padded-bottom-page"></div> </div> </div> </div> <div class="tabContent flex flex-direction-column flex-grow" data-index="2"> </div> </div> When I use this code, custom links are fixed. However, the side scroll bar disappears and it is not possible to scroll up or down. This only happens with the home page
Guest Posted November 10, 2022 Posted November 10, 2022 Hi, I don't believe it's exactly this code that blocks the scroll on the screen, because I use it and I don't have this problem. I believe that it is some conflict between codes that causes this event, as I have now noticed that only on mobile some screens are frozen for scrolling (on PC this problem does not exist) so we need to investigate to find out the reason for this, as it only happens on some screens , with the scrolling of the tv screen, only on the pc, in my case.
Happy2Play 9811 Posted November 10, 2022 Posted November 10, 2022 @Alexwerilles Can you elaborate as I have not seen this issue in testing.
Alexwerilles 3 Posted November 17, 2022 Posted November 17, 2022 On 11/10/2022 at 1:35 PM, Happy2Play said: @Alexwerilles Can you elaborate as I have not seen this issue in testing. using the code that you informed, ends up running out of scrollbar. With the original code, the slash appears normally
Guest Posted November 17, 2022 Posted November 17, 2022 Hi, would it be possible to find a way to fix this personal links mess? On the PC it's perfect but on the cell phone everything is misaligned in any browser as shown in the image. Thanks
Happy2Play 9811 Posted November 17, 2022 Posted November 17, 2022 @Alexwerilles What browser as I have a scrollbar on all my tests and dimensions.
Alexwerilles 3 Posted November 18, 2022 Posted November 18, 2022 9 hours ago, Happy2Play said: @Alexwerilles What browser as I have a scrollbar on all my tests and dimensions. Why does this happen to me? Is the best option for me to use css?
Luke 42239 Posted November 18, 2022 Posted November 18, 2022 35 minutes ago, Alexwerilles said: Why does this happen to me? Is the best option for me to use css? If you remove the custom css, do you get your scrollbar back?
Alexwerilles 3 Posted November 18, 2022 Posted November 18, 2022 5 hours ago, Luke said: If you remove the custom css, do you get your scrollbar back? I already did this test. Still no scrollbar when removing css
Happy2Play 9811 Posted November 18, 2022 Posted November 18, 2022 7 hours ago, Alexwerilles said: 13 hours ago, Luke said: If you remove the custom css, do you get your scrollbar back? I already did this test. Still no scrollbar when removing css I am confused then as that means it has nothing to do with mentioned code/css. Or are you saying modifying the home.html is causing this issue? If so can you post or pm it. What browser and version number?
Alexwerilles 3 Posted November 18, 2022 Posted November 18, 2022 2 hours ago, Happy2Play said: I am confused then as that means it has nothing to do with mentioned code/css. Or are you saying modifying the home.html is causing this issue? If so can you post or pm it. What browser and version number? modifying the home.html I did the test on Chrome version 107.0.5304.107 and Edge, both have this problem <div class="view flex flex-direction-column withTabs"> <div class="tabContent flex flex-grow" data-index="0"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-direction-column flex-grow focuscontainer-down" data-bindheader="true"> <div class="Personal-Links" style="top:120px;text-align:center;position:relative;"> <a is="emby-linkbutton" class ="button-link" href="LINK#1" target="_blank" style="text-decoration: none;color: #D3D3D3 ;margin: 0 .7em; ">TEXT1</a> <a is="emby-linkbutton" class="button-link" href="LINK#2" <a is="emby-linkbutton" class="button-link" href="LINK#3" target="_blank" style="text-decoration: none;color: #D3D3D3 ;margin: 0 .7em ;"> TEXT3</a> <a is="emby-linkbutton" class="button-link" href="LINK#4" target="_blank" style="text-decoration: none;color: #D3D3D3 ;margin: 0 .7em; "> TEXT4</a> <a is="emby-linkbutton" class="button-link" href="LINK#5" target="_blank" style="text-decoration: none;color: #D3D3D3 ;margin: 0 .7em; "> TEXT5</a> <pré> </div> <div class="scrollSlider flex-grow padded-top-page"> <div class="sections"></div> <div class="padded-bottom-page"></div> </div> </ div> </div> <div class="tabContent flex flex-grow" data-index="1"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands= "card" data-forcescrollbar="true" class="scrollFrameY flex flex-grow focuscontainer-down" data-bindheader="true"> <div class="scrollSlider flex-grow padded-top-page"> <div class="sections"></div> <div class="padded-bottom-page"></div> </div> </ div> </div> <div class="tabContent flex flex-direction-column flex-grow" data-index="2"> </div> </div>
Luke 42239 Posted November 18, 2022 Posted November 18, 2022 Do you have a touch input device connected?
Happy2Play 9811 Posted November 18, 2022 Posted November 18, 2022 (edited) @Alexwerilles Had to compare Old HTML to New Html as old code does not have "tabContent-positioned" So it needs added to each or readd Personal-Links to a new home.html. <div class="view flex flex-direction-column withTabs"> <div class="tabContent tabContent-positioned flex flex-grow" data-index="0"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-direction-column flex-grow focuscontainer-down" data-bindheader="true"> <div class="Personal-Links" style="top:110px;text-align:center;position:relative;"> <a is="emby-linkbutton" class="button-link" href="LINK#1" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">LINK#1</a> <a is="emby-linkbutton" class="button-link" href="LINK#2" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">LINK#2</a> <a is="emby-linkbutton" class="button-link" href="LINK#3" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">LINK#3</a> <a is="emby-linkbutton" class="button-link" href="LINK#4" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">LINK#4</a> <a is="emby-linkbutton" class="button-link" href="LINK#5" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">LINK#5</a> <pre></pre> </div> <div class="scrollSlider flex-grow padded-top-page"> <div class="sections"></div> <div class="padded-bottom-page"></div> </div> </div> </div> <div class="tabContent tabContent-positioned flex flex-grow" data-index="1"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-grow focuscontainer-down" data-bindheader="true"> <div class="scrollSlider flex-grow padded-top-page"> <div class="sections"></div> <div class="padded-bottom-page"></div> </div> </div> </div> </div> Edited November 19, 2022 by Happy2Play
Alexwerilles 3 Posted November 19, 2022 Posted November 19, 2022 1 hour ago, Happy2Play said: @Alexwerilles Had to compare Old HTML to New Html as old code does not have "tabContent-positioned" So it needs added to each or readd Personal-Links to a new home.html. <div class="view flex flex-direction-column withTabs"> <div class="tabContent tabContent-positioned flex flex-grow" data-index="0"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-direction-column flex-grow focuscontainer-down" data-bindheader="true"> <div class="Personal-Links" style="top:110px;text-align:center;position:relative;"> <a is="emby-linkbutton" class="button-link" href="LINK#1" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">HomeTv</a> <a is="emby-linkbutton" class="button-link" href="LINK#2" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">Apps</a> <a is="emby-linkbutton" class="button-link" href="LINK#3" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">Assinantes</a> <a is="emby-linkbutton" class="button-link" href="LINK#4" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">Blog</a> <a is="emby-linkbutton" class="button-link" href="LINK#5" target="_blank" style="text-decoration: none;color: #D3D3D3;margin:0 0.7em;">Grupo</a> <pre></pre> </div> <div class="scrollSlider flex-grow padded-top-page"> <div class="sections"></div> <div class="padded-bottom-page"></div> </div> </div> </div> <div class="tabContent tabContent-positioned flex flex-grow" data-index="1"> <div is="emby-scroller" data-horizontal="false" data-centerfocus="true" data-navcommands="card" data-forcescrollbar="true" class="scrollFrameY flex flex-grow focuscontainer-down" data-bindheader="true"> <div class="scrollSlider flex-grow padded-top-page"> <div class="sections"></div> <div class="padded-bottom-page"></div> </div> </div> </div> </div> it works, thanks How can I separate the personal link a little from "sections/my media"
Happy2Play 9811 Posted November 19, 2022 Posted November 19, 2022 26 minutes ago, Alexwerilles said: it works, thanks How can I separate the personal link a little from "sections/my media" Not sure I follow but might be any additional css you have. This is only editing home.html and headermiddle.
Alexwerilles 3 Posted November 19, 2022 Posted November 19, 2022 2 hours ago, Happy2Play said: Not sure I follow but might be any additional css you have. This is only editing home.html and headermiddle. that's right. What was causing this was this code to hide "My Media" div.section0 div.sectionTitleContainer {display: none;} thanks
Happy2Play 9811 Posted November 19, 2022 Posted November 19, 2022 7 hours ago, Alexwerilles said: that's right. What was causing this was this code to hide "My Media" div.section0 div.sectionTitleContainer {display: none;} thanks Easiest route would be change to visibility: hidden; but can look at --extra-padding-top or --header-height if needed.
Guest Posted November 19, 2022 Posted November 19, 2022 (edited) "So it needs added to each or readd Personal-Links to a new home.html." Hi, I have a few screens only on mobile that are missing the scroll bar. What would the CSS completion look like to use this option in red? Thanks Edited November 19, 2022 by CarlosLima
