ctyank 1 Posted September 30, 2014 Posted September 30, 2014 So I love Chocolate's poster configuration. I puts the logo in the bottom left with a black/dark background. I love the layout and found it nearly perfect for me. However, I've noticed that the logos for certain titles are getting vertically stretched. The titles are stretched taller than they should be. For example, the "O" in Oblivion should be a perfect circle. Instead, I am seeing A standard elongated "O". I tried the other views under Chocolate and none of them seemed to have the same problem, so I think is just the poster view. Some other example titles would be Stargate, Chronicle and Phenomenon. Is anyone else seeing the same stretching?
MrWebsmith 598 Posted September 30, 2014 Posted September 30, 2014 can you give me a screenshot and ill compare to my setup and report back...
ctyank 1 Posted September 30, 2014 Author Posted September 30, 2014 Sure. I'll take care of that later this evening. Thanks for helping out!!!
ctyank 1 Posted October 1, 2014 Author Posted October 1, 2014 Sorry I couldn't get that into one post. Anyway, these are three good examples. It doesn't affect every movie. In fact, most look fine. All three of these look good in Chocolate except when in poster mode.
ebr 16344 Posted October 1, 2014 Posted October 1, 2014 Yeah, I think I can take care of this. It will mean smaller logos in some instances.
MrWebsmith 598 Posted October 1, 2014 Posted October 1, 2014 good screenshots OP.. they def. help the cause.
ctyank 1 Posted October 1, 2014 Author Posted October 1, 2014 Yeah, I think I can take care of this. It will mean smaller logos in some instances. Thanks! I figured that the issue was that the space for the logo is limited and the width was adjusted to fit. In order to get the aspect ratio correct, the logos will have adjust vertically as well (getting shorter) meaning that such logos will overall appear smaller.
ctyank 1 Posted October 1, 2014 Author Posted October 1, 2014 good screenshots OP.. they def. help the cause. Thank you! I do some system support too... the pics are always worth 1,000 words.
ebr 16344 Posted October 2, 2014 Posted October 2, 2014 Updates to Chocolate are always delivered with MBC. A new beta will be going out today.
ctyank 1 Posted October 2, 2014 Author Posted October 2, 2014 Woo-hoo! That looks great! Thank you so much for that update. So many logos look lots better now. 1
