wanderjarra 18 Posted June 20, 2022 Posted June 20, 2022 21 hours ago, Luke said: Apologies for the disruption. New builds of 4.7.3 are on the way up and should be finished uploading within the next hour. Additionally we're going to tag a 4.7.4 after that just to ensure that everyone gets notified that there is an update/resolution available. I was afraid of losing the data and installed beta 4.8.0.2 on DSM 6, can I go back to version 4.7.4.0 normally or do I have to uninstall it and then put the stable version? When I tried to go back to version 4.7.2.0, I got the message that I couldn't downgrade, I didn't know about the uninstall option...
Luke 42243 Posted June 20, 2022 Posted June 20, 2022 3 hours ago, wanderjarra said: I was afraid of losing the data and installed beta 4.8.0.2 on DSM 6, can I go back to version 4.7.4.0 normally or do I have to uninstall it and then put the stable version? When I tried to go back to version 4.7.2.0, I got the message that I couldn't downgrade, I didn't know about the uninstall option... You can try, but it might make you uninstall first, which doesn't clear the program data folder.
Houseboy 2 Posted June 21, 2022 Posted June 21, 2022 The Newbuild doesn't work for me. My current Version is 4.7.2 and on my DS216j is Version 7.1 .... Update 2 newest Version. After Install 4.7.4 emby start fail.
unisoft 355 Posted June 21, 2022 Posted June 21, 2022 19 hours ago, clessy said: New build 4.7.4.0 works fine at DS 1819+ 4.7.4.0 Fine for me on DS2415+. Live TV Guide channel re-ordering bug fixed too.
JohnDoe83 1 Posted June 21, 2022 Posted June 21, 2022 4.7.3 and 4.7.4 doesn’t work on my DS216 Play (DSM 7.1) « failure initiating package repair » reinstall 4.7.2. Work fine
Luke 42243 Posted June 21, 2022 Posted June 21, 2022 54 minutes ago, JohnDoe83 said: 4.7.3 and 4.7.4 doesn’t work on my DS216 Play (DSM 7.1) « failure initiating package repair » reinstall 4.7.2. Work fine HI there, can you please try it again?
Houfino 41 Posted June 21, 2022 Posted June 21, 2022 Před 1 hodinou JohnDoe83 řekl: 4.7.3 a 4.7.4 nefungují na mém DS216 Play (DSM 7.1) " poruchového inicializujícího _ balíčku _ Oprava " přeinstalovat 4.7.2. Pracujte dobře It doesn't work for me either.... I have the same DS216Play (DSM 7.1)..Version 4.7.4.0 does not work for me
JohnDoe83 1 Posted June 21, 2022 Posted June 21, 2022 2 hours ago, Luke said: HI there, can you please try it again? Hi, uninstall 4.7.2 before or just update with 4.7.4 ?
JohnDoe83 1 Posted June 22, 2022 Posted June 22, 2022 (edited) 16 hours ago, Luke said: I would just try installing over the top. Install 4.7.4 again and doesn’t work Edited June 22, 2022 by JohnDoe83
Houfino 41 Posted June 22, 2022 Posted June 22, 2022 Where can I find older versions 4.7.2.0 for DS216Play (DSM 7.1) ?? The newer version doesn't work for me and that's bad ... Thank you
JohnDoe83 1 Posted June 22, 2022 Posted June 22, 2022 2 minutes ago, Houfino said: Where can I find older versions 4.7.2.0 for DS216Play (DSM 7.1) ?? The newer version doesn't work for me and that's bad ... Thank you https://github.com/MediaBrowser/Emby.Releases/releases 1
Houfino 41 Posted June 22, 2022 Posted June 22, 2022 Just now, JohnDoe83 said: https://github.com/MediaBrowser/Emby.Releases/releases Thank you!!!
Sandmann 1 Posted June 22, 2022 Posted June 22, 2022 DS720+ with DSM 7.1-42661 Update 2 work fine. Emby 4.7.4.0 Updated from 4.7.3.0 1
MAX92 93 Posted June 23, 2022 Posted June 23, 2022 DS220+ DSM 7.1-42661 Update 1 work fine Emby 4.7.4.0 Updated from 4.7.3.0
vitoraguiar 1 Posted June 27, 2022 Posted June 27, 2022 Hi everyone DS218j with DSM 7.1-42661 Update 2 Version emby-server-synology7_4.7.5.0_armv7.spk do not work. After Install 4.7.5 emby start fail Version emby-server-synology7_4.7.4.0_armv7.spk do not work. After Install 4.7.4 emby start fail reinstall 4.7.2. Work fine
JohnDoe83 1 Posted June 28, 2022 Posted June 28, 2022 Hi On DS216Play with DSM 7.1-42661 update 2 Emby 4.7.5 does not work
Houfino 41 Posted June 28, 2022 Posted June 28, 2022 Před 22 minutami JohnDoe83 řekl: Ahoj Na DS216Play s DSM 7.1-42661 aktualizace 2 Emby 4.7.5 nefunguje I have the same..I had to stay version 4.7.2.0 ... Looks like the DS216Play probably has a problem due to older production or I don't know.....
JohnDoe83 1 Posted June 28, 2022 Posted June 28, 2022 11 minutes ago, Houfino said: I have the same..I had to stay version 4.7.2.0 ... Looks like the DS216Play probably has a problem due to older production or I don't know..... On DS218 same problem too
alucryd 318 Posted June 28, 2022 Posted June 28, 2022 (edited) Does the latest beta start? Will fix the stable release, but I'd like to know if there's a deeper issue. Also do you guys have some log about the error? Can someone try to run emby manually via SSH? sudo -u emby /var/packages/EmbyServer/target/bin/emby-server Off the top of my head, the above line should do just that. Edited June 28, 2022 by alucryd
Luke 42243 Posted June 28, 2022 Posted June 28, 2022 Hi, please try downloading 4.7.5 from our website again and let us know how that compares. Thanks ! 1
