Benjocharles 0 Posted June 19, 2022 Posted June 19, 2022 (edited) I'm not able to log in via the fire TV app. It keeps freezing and then going back to the main fire TV menu. So the app crashes. I can log in on other firesticks at other locations so I'm not sure if it's this specific model. I tried clearing cache and data and completely uninstalling and reinstalling but the same outcome happens. I just sent the logs from it. It's being accessed over the internet. Edited June 19, 2022 by Benjocharles
Benjocharles 0 Posted June 19, 2022 Author Posted June 19, 2022 (edited) I was able to connect the firestick to a Hotspot instead of the regular wifi and login just fine in the app. I logged in and then switched over to the regular wifi and was able to use emby. However if I log out and try to log in the freezing happens again. So it's something with this wifi. Not sure what it could be. Edited June 19, 2022 by Benjocharles
ebr 16337 Posted June 19, 2022 Posted June 19, 2022 Hi. It appears something on the network is interfering with the response from your server. Are you going through some sort of proxy?
Benjocharles 0 Posted June 19, 2022 Author Posted June 19, 2022 No nothing at all. It's just strange that it's only on the emby fire TV app. If I go to the browser on the firestick I can log in just fine. So it's something specific to the app. Is there a way I can get a copy of the log to see if I can narrow down the issue?
ebr 16337 Posted June 19, 2022 Posted June 19, 2022 The issue is for sure something on the network interfering with the data being passed to the app. We've seen this happen with proxies or some security type watchdog apps on networks. The app gets JSON from the server and that JSON is being modified such that it is no longer valid JSON and the deserializer is crashing. The key may be that it is a Fire device as I've seen some of these watchdogs do things for specific device types (and Fires seem to be one of the most common).
Luke 42245 Posted June 28, 2022 Posted June 28, 2022 Hi, can you try sideloading our standard app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks.
