Alda76 8 Posted March 3, 2023 Author Posted March 3, 2023 anonymised this. in putty, logged in as admin i am trying to get persmission to run this command.
Alda76 8 Posted March 3, 2023 Author Posted March 3, 2023 But it appears the task itself is not working. i am stuck now trying to change it via putty/terminal
Alda76 8 Posted March 3, 2023 Author Posted March 3, 2023 Ok after a short crash course from scratch i seem to have set the correct value. Will this number persist after a restart/boot?
Alda76 8 Posted March 3, 2023 Author Posted March 3, 2023 Im also located the output. somehow the script was missing a space between > Fixed this in the script file (the job was ok???) After i re-ran the job i now get an empty output, which looks allright i think? No error at least
Alda76 8 Posted March 3, 2023 Author Posted March 3, 2023 for those after me, u can find the output location via settings button
Alda76 8 Posted March 3, 2023 Author Posted March 3, 2023 After reboot, checked all values and the output of the job. all good values now! thx
Alda76 8 Posted March 3, 2023 Author Posted March 3, 2023 Still not seeing emby pick up a new episode
Alda76 8 Posted March 3, 2023 Author Posted March 3, 2023 Don't see anything in the log. i downloaded young sheldon s06e14 embyserver (2).txt
Happy2Play 9811 Posted March 3, 2023 Posted March 3, 2023 Because you still have iNotify errors. Error in Directory watcher for: /volume5/SeriesV5 The configured user limit (8192) on the number of inotify watches has been reached, or the operating system failed to allocate a required resource. Try this 1
Alda76 8 Posted March 4, 2023 Author Posted March 4, 2023 ok,. just to be clear, i added this to the task and removed the old: sysctl fs.inotify.max_user_watches=1048576; sysctl fs.inotify.max_user_instances=4096; I just ran it manually. output files: Then i rebooted. hope this fixes the issue, tysm. Will let u know what happened
Alda76 8 Posted March 4, 2023 Author Posted March 4, 2023 ok looks like that fixed it!! Getting new episodes imported now automagically. tysm!! 1
Alda76 8 Posted March 6, 2023 Author Posted March 6, 2023 (edited) ok looks like that fixed it!! Getting new episodes imported now automagically. tysm!! Update: or so thought...my happyness was shortlivedlog.txt This morning it did not add another 2 show episodes... Edited March 6, 2023 by Alda76
GrimReaper 4896 Posted March 6, 2023 Posted March 6, 2023 That doesn't appear to be Emby server log you've attached but *arr app log.
Alda76 8 Posted March 6, 2023 Author Posted March 6, 2023 (edited) My bad, here is the correct file. i don't see any inotify msgs when i search for it embyserver.txt An episode got done at 3:23 am and at 5:25 am Edited March 6, 2023 by Alda76
Alda76 8 Posted March 8, 2023 Author Posted March 8, 2023 ok looks like that fixed it!! Getting new episodes imported now automagically. tysm!! And now it seems to be working again. this is really confusing 1
Alda76 8 Posted March 9, 2023 Author Posted March 9, 2023 (edited) ok looks like that fixed it!! Getting new episodes imported now automagically. tysm!! And now it seems to be working again. this is really confusingembyserver (1).txt Well sometimes it works, other times it doesn't. now it hasn't again...Can someone help me figure out why it is not working (again) i don't see any inotify msgs. at 6.40 am south park should have been added, but it is not in emby, but it is in my server. it's now past 11 am Edited March 9, 2023 by Alda76
Alda76 8 Posted March 9, 2023 Author Posted March 9, 2023 And after a restart all is added again...this is really frustrating. is there something that is blocking the scanner? like a previous scan?
Alda76 8 Posted March 9, 2023 Author Posted March 9, 2023 (edited) maybe this? Edited March 9, 2023 by Alda76
Luke 42242 Posted March 9, 2023 Posted March 9, 2023 When the scan is active, the realtime monitor is disabled. It's something we plan to improve on in future updates. Thanks.
Happy2Play 9811 Posted March 9, 2023 Posted March 9, 2023 Yes monitoring stops during scans but items can be put in a queue per the RTM timer if not caught during scan and added the scan finishes. Info LibraryMonitor: Stopping directory watching for path xxxxxxxxxxxxxxxxxxxxx
