Dickydodah! 154 Posted June 18, 2022 Posted June 18, 2022 I have noticed that when playing back any video the dot on the progrss indicator does not move from the 0 position. If you skip forward it moves to that position but stays there. This started happening in 1.2.8 but I never got round to reporting it The issue is still there in 1.2.9 along with another issue I have reported. Samsung model number: UE43KU6510 Samsung firmware version: 1250 Samsung Emby client version: 1.2.9 Emby server version: 4.7.2.0 1
FrostByte 5453 Posted June 18, 2022 Posted June 18, 2022 (edited) I'm not seeing this one either on my 2018. Using 4.8.0.2 beta server I can't see the dot physically moving across, but when the OSD is up I can see it blink. I assume the blink is the part of the code refreshing the position of the dot and it's just a very slight move with movies and don't notice it. However, if I wait 5 - 10 minutes and bring the OSD back up again the dot has moved from the last time I looked at the OSD. Maybe an issue with 2016s? Edited June 18, 2022 by FrostByte
Dickydodah! 154 Posted June 18, 2022 Author Posted June 18, 2022 My 2017 model doen't have the issue on 1.2.7 or 1.2.8 but on my 2016 the dot isn't blinking or moving. 1
SamES 1084 Posted June 18, 2022 Posted June 18, 2022 @Luke, it looks like requestAnimationFrame() is never being called to update the value for the slider on the older models. 1
TamerEce 2 Posted July 20, 2022 Posted July 20, 2022 The seek/progress bar problem still exists in 1.3.0 Best Regards
Luke 42241 Posted July 22, 2022 Posted July 22, 2022 HI, please let me know if this build resolves the issue for you: tizen.zip Thanks.
Dickydodah! 154 Posted July 22, 2022 Author Posted July 22, 2022 Hi @Luke, That looks like it has fixed it for my UE43KU6510 and UE32M5500
Dickydodah! 154 Posted July 22, 2022 Author Posted July 22, 2022 Now just need to fix the themes on older models and I'll be very happy Or maybe an excuse to buy a new TV
TamerEce 2 Posted July 22, 2022 Posted July 22, 2022 4 hours ago, Luke said: HI, please let me know if this build resolves the issue for you: tizen.zip 19.76 MB · 1 download Thanks. This build worked for me too ! Many thanks Luke Best Regards 1
Luke 42241 Posted July 22, 2022 Posted July 22, 2022 Thanks. I've posted a 1.3.1 update with this fix. 1
