TJSNHS04 9 Posted June 18, 2022 Posted June 18, 2022 (edited) As in the video and photos, it no longer loads the images, if you click them individually, it loads them, even deleting the metadata and redoing the new scan of the metadata etc it does not work Come da video e foto, non carica piu le immagini,se si clicca singolarmente le carica, anche cancellando i metadati e rifacendo la scansione nuova dei metadati etc non funziona 2022-06-18 10:43:29.990 Error Server: Error processing request *** Error Report *** Version: 4.7.2.0 Command line: C:\Users\XXXXXXXXXXXX\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.19044 Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: C:/Users/XXXXXXXXXXXX/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\XXXXXXXXXXXX\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\XXXXXXXXXXXX\AppData\Roaming\Emby-Server\system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path 'M:\metadada lib\metadata\people\Alana de la Garza-tmdb-1218281\folder.jpg'. at Emby.Drawing.Skia.SkiaEncoder.GetSKFileStream(String path) at Emby.Drawing.Skia.SkiaEncoder.EncodeImage(String inputPath, String outputPath, Boolean autoOrient, Nullable`1 orientation, Int32 quality, ImageProcessingOptions options, ImageFormat selectedOutputFormat) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) at Emby.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Drawing.Skia TargetSite: SkiaSharp.SKFileStream GetSKFileStream(System.String) Path: M:\metadada lib\metadata\people\Alana de la Garza-tmdb-1218281\folder.jpg As per log it does not find the image but the image is the path and correct Come da log non trova l immagine mha l immagine c'è il percorso e corretto castcrew.mp4 Edited June 18, 2022 by TJSNHS04
TJSNHS04 9 Posted June 21, 2022 Author Posted June 21, 2022 1 hour ago, Happy2Play said: Please post a complete server log. i solved by forcing from the task schedule settings, repeatedly until after 4.7.4 update and further forcing is going
