Mentalblaze 9 Posted June 17, 2022 Posted June 17, 2022 I have a server and Streaming to my TV Android box. Suddenly DTS have stopped working an HD movies are hacking terribly. If I switch to another audio stream, I get sound and the hacking dissapears. The Version is 2.0.70g. I tried with a restart and deleting the cache. That didn’t help. As a comparison is that I have a LG Webos on the TV I use, so if I use Emby on that, I get DTS and everything runs smoothly. But it is easier to use the same box for everything… What can I do to fix this?
Luke 42238 Posted June 17, 2022 Posted June 17, 2022 Hi there, can we please look at an example? Thanks !
Mentalblaze 9 Posted June 18, 2022 Author Posted June 18, 2022 ”Solved” it by turning off dts pass through in the app settings.
Luke 42238 Posted June 18, 2022 Posted June 18, 2022 Can you try sideloading our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks.
Mentalblaze 9 Posted June 22, 2022 Author Posted June 22, 2022 That app was not supported on the device. Should I try an .apk? Not sure if it’s arm or x86, though.
Luke 42238 Posted July 2, 2022 Posted July 2, 2022 On 6/22/2022 at 8:16 AM, Mentalblaze said: That app was not supported on the device. Should I try an .apk? Not sure if it’s arm or x86, though. Hi @Mentalblaze most likely you need the armv7 version. Can you please try that?
Mentalblaze 9 Posted August 2, 2022 Author Posted August 2, 2022 Hi! OK, I have now tried this. I have Emby Server 4.6.7.0 amd the Emby for Android have 3.2.61.And I selected to play two different movies that I have in two editions. 1. First are UHD HEVC and audio AAC 7.1. Second is 720p h264 with DTS 5.1. First played without any issues, the other hacking and no audio. 2. First are UHD HEVC and audio DTS-HD MA 7.1. Second 720p H264 audio AC3. The first is hacking and no audio, while the second works fine. So DTS is the common thing on the none working. To verify the system, I also tested on emby on my LG (1.0.35) and DTS is passed to my speakers. I had to login through Emby Connect, as I couldn't trigger a keyboard on the tested apk. So it was problems getting the films to start. But if I started on the original Emby app and then switched to the tested one, I could get them to play properly. I removed the public URL from the logs, I doubt you need that. I have also saved the transcode logs created, if you need those as well. embyserver.txt
ebr 16332 Posted August 2, 2022 Posted August 2, 2022 5 minutes ago, Mentalblaze said: I have Emby Server 4.6.7.0 Hi. Can you please update to 4.7.x?
Luke 42238 Posted August 2, 2022 Posted August 2, 2022 Hi, yes please attach the ffmpeg log files as well. Thanks
Mentalblaze 9 Posted August 2, 2022 Author Posted August 2, 2022 I am currently working on upgrading my OpenMediaVault, where the Emby server is located. I’ll upgrade Emby too, when I am done with that. Reason for the upgrade is that Docker have issues fetching new containers…
Mentalblaze 9 Posted August 2, 2022 Author Posted August 2, 2022 For the time being, here is the mpg logs ffmpeg-transcode-9179dbb1-3b1e-45e7-a4e1-173c0b76fbef_1.txt ffmpeg-transcode-6d322472-c24f-446d-aa07-76bd7f2e194b_1.txt ffmpeg-remux-bffd4974-5724-41f9-aecc-e109a5b0f4b7_1.txt ffmpeg-transcode-bbd05d30-8446-4249-8706-a4523b74fac3_1.txt ffmpeg-transcode-a5c86edd-f324-480f-8d0f-97a739d72051_1.txt
Mentalblaze 9 Posted August 3, 2022 Author Posted August 3, 2022 I have got most of the upgrade sorted now and I have upgraded to 4.7.6.0. Same issue though, in both the app for android TV as well as the Android APK. A separate hardware question but related to the Emby server: Would I get better performance for transcoding etc if I installed a separate graphic card? I only use the graphics that comes with the motherboard currently. ffmpeg-remux-42bd945d-0c03-42c9-8021-5a46d78d7b41_1.txt embyserver.txt
Luke 42238 Posted September 3, 2022 Posted September 3, 2022 Hi, can you try the newest version of our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks.
