zetetic 5 Posted June 16, 2022 Posted June 16, 2022 This would be useful functionality. For some reason every few days I can't connect to Emby from outside my network, but I can still connect to my Jriver server running on the same PC. Once I restart Emby it is fine again.
Luke 42186 Posted June 16, 2022 Posted June 16, 2022 Hi @zetetic let's try to get to the bottom of this. Can you please attach the emby server log from when this happens? Thanks !
Solution zetetic 5 Posted June 17, 2022 Author Solution Posted June 17, 2022 No problem. Looks like there is a lot of info in the logs I probably do not want on a public forum. There are a lot of port mapping errors which seem a likely problem. These keep repeating in the logs. Is this enough data to know something? 2022-06-17 07:32:01.141 Error PortMapper: Error in GetSpecificMappingAsync *** Error Report *** Version: 4.7.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-113-generic (buildd@lcy02-amd64-067) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #127-Ubuntu SMP Wed May 18 14:30:56 UTC 2 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.IO.IOException: The response ended prematurely. at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.GetSpecificMappingAsync(Protocol protocol, Int32 publicPort, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.IO.IOException: The response ended prematurely. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) 2022-06-17 07:32:01.147 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body> <s:Fault> <faultcode>s:Client</faultcode> <faultstring>UPnPError</faultstring> <detail> <UPnPError xmlns="urn:schemas-upnp-org:control-1-0"> <errorCode>402</errorCode> <errorDescription>Invalid Args</errorDescription> </UPnPError> </detail> </s:Fault> </s:Body> </s:Envelope> 2022-06-17 07:32:01.148 Error PortMapper: Error in DeletePortMap *** Error Report *** Version: 4.7.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-113-generic (buildd@lcy02-amd64-067) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #127-Ubuntu SMP Wed May 18 14:30:56 UTC 2 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body> <s:Fault> <faultcode>s:Client</faultcode> <faultstring>UPnPError</faultstring> <detail> <UPnPError xmlns="urn:schemas-upnp-org:control-1-0"> <errorCode>402</errorCode> <errorDescription>Invalid Args</errorDescription> </UPnPError> </detail> </s:Fault> </s:Body> </s:Envelope> at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.DeletePortMap(Mapping mapping, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2022-06-17 07:32:01.208 Error PortMapper: Error creating port map *** Error Report *** Version: 4.7.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-113-generic (buildd@lcy02-amd64-067) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #127-Ubuntu SMP Wed May 18 14:30:56 UTC 2 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.IO.IOException: The response ended prematurely. at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMapInternal(Mapping mapping, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.IO.IOException: The response ended prematurely. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) Coincidentally, the problem was occurring right now and I think I just solved it myself by manually adding the port mapping in my router. I very much appreciate the time to consider this.
Luke 42186 Posted July 2, 2022 Posted July 2, 2022 Quote Coincidentally, the problem was occurring right now and I think I just solved it myself by manually adding the port mapping in my router. HI @zetetic so are you all set now, or are you still having an issue with this?
zetetic 5 Posted July 4, 2022 Author Posted July 4, 2022 Looks like port mapping sorted it out, thanks
