gogreenpower 26 Posted June 16, 2022 Posted June 16, 2022 Hi Guys, I have my kids account set up with a "maximum" rating, which works great, but is there a way to set a "minimum" rating so my I dont see all the kids movies in my account?
GrimReaper 4851 Posted June 16, 2022 Posted June 16, 2022 (edited) Filter by Parental Rating in the appropriate library. Edit: If kids movies are kept in a separate folder, disable access to that folder for yourself. Alternatively, tag all your kids' movies and "Block items with these tags" for your user. Edited June 16, 2022 by GrimReaper
gogreenpower 26 Posted June 16, 2022 Author Posted June 16, 2022 Been looking at "tags". Can you do a bulk tag of movies?
Junglejim 385 Posted June 16, 2022 Posted June 16, 2022 17 minutes ago, gogreenpower said: Been looking at "tags". Can you do a bulk tag of movies? Hi mate, there is a tool available that can bulk edit tags and works quite well.. https://emby.media/community/index.php?/topic/99809-a-tool-for-tagging-emby-content/ 1 1
ebr 16307 Posted June 16, 2022 Posted June 16, 2022 7 hours ago, GrimReaper said: Edit: If kids movies are kept in a separate folder, disable access to that folder for yourself. This is how I suggest accomplishing this. Folder Based Access Control
gogreenpower 26 Posted June 17, 2022 Author Posted June 17, 2022 21 hours ago, ebr said: This is how I suggest accomplishing this. Folder Based Access Control that was how I had it set, but I needed to recently combine all my movie folders into one mega folder. Tags seem to be working.
