flipside 6 Posted June 15, 2022 Posted June 15, 2022 Hi , i have a set of Bose NC700 headphones connected to my 2015 SHield running the lastest update (not beta). The playback controls are not being recognised using emby but are in Netflix.Prime,Pluto, youtube and other media playing apps. am i missing a setting and if not is there any information i can supply thast could help shed any light ? ta Matt
Luke 42243 Posted June 15, 2022 Posted June 15, 2022 Hi, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
flipside 6 Posted June 15, 2022 Author Posted June 15, 2022 (edited) 24 minutes ago, Luke said: Hi, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks ! ok so i sideloaded and the android version reacts to the playback controls but doesn't seem to pipe the sound over Bluetooth or respond to volume controls AndroidTV version has audio over Bluetooth and volume controls Edited June 15, 2022 by flipside update
Luke 42243 Posted July 21, 2022 Posted July 21, 2022 @flipside can you please try the latest Emby for Android app update (3.2.57), and let me know how that compares: https://emby.media/emby-for-android.html Thanks !
Solution flipside 6 Posted July 26, 2022 Author Solution Posted July 26, 2022 On 21/07/2022 at 01:24, Luke said: @flipside can you please try the latest Emby for Android app update (3.2.57), and let me know how that compares: https://emby.media/emby-for-android.html Thanks ! Hi , sorry to take a while to get back but i was on holiday. Ive tested it and the new Android one work perfectly with my bose. 1
flipside 6 Posted September 3, 2023 Author Posted September 3, 2023 Sorry to necro post but are the Bluetooth fixes coming to the TV version as having to sideload and manually up the default android version is a pain, it also doesn't seem to allow for selecting a profile on start which has lead to some confusion around where people are in a series.
Luke 42243 Posted September 3, 2023 Posted September 3, 2023 1 hour ago, flipside said: Sorry to necro post but are the Bluetooth fixes coming to the TV version as having to sideload and manually up the default android version is a pain, it also doesn't seem to allow for selecting a profile on start which has lead to some confusion around where people are in a series. Hi, we are working on getting it into the store for TV devices and will be adding new login options soon. Thanks.
redtransfer 0 Posted January 6, 2024 Posted January 6, 2024 Hi is this issue resolved? My Bluetooth headphones give me audio but no controls for play or pause. I've auto updates on my Nvidia Shield Pro and Shield TV units. Thank in advance for any guidance to fix.
Luke 42243 Posted January 6, 2024 Posted January 6, 2024 6 minutes ago, redtransfer said: Hi is this issue resolved? My Bluetooth headphones give me audio but no controls for play or pause. I've auto updates on my Nvidia Shield Pro and Shield TV units. Thank in advance for any guidance to fix. @redtransfer Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Luke 42243 Posted October 25, 2025 Posted October 25, 2025 @redtransferyou said: Quote I tried looking thru web browser online but couldn't even find anything. Did you try clicking add server and entering the server information?
Luke 42243 Posted October 25, 2025 Posted October 25, 2025 @redtransfer Quote Also another nag message that says "unable to get upcoming items" Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
