musicmafia 38 Posted June 15, 2022 Posted June 15, 2022 (edited) I'm obviously not very tech savvy as I can't seem to figure out something that I'm guessing is quite easy. I had to move all my media files to a larger drive in a different port with a different drive letter. I've spent an hour logged in to my Emby account and searching the forum, but I still can't figure out how to navigate to the section where I can choose the new drive. Can anyone give me a step by step? Thanks! Edited June 15, 2022 by musicmafia
GrimReaper 4851 Posted June 15, 2022 Posted June 15, 2022 Settings>Library, edit any library. Note that if drive letter/folder structure change, all items will have to be rescanned/readded as if new. 1
musicmafia 38 Posted June 15, 2022 Author Posted June 15, 2022 5 minutes ago, GrimReaper said: Settings>Library, edit any library. Note that if drive letter/folder structure change, all items will have to be rescanned/readded as if new. Yes, that is what I am trying to do. How do I have Emby stop scanning the old drive and start scanning the new one?
GrimReaper 4851 Posted June 15, 2022 Posted June 15, 2022 7 minutes ago, GrimReaper said: Settings>Library, edit any library. Under "Folders" section, remove old path(s)/add new path(s). 1
musicmafia 38 Posted June 15, 2022 Author Posted June 15, 2022 Is this the right location? It's showing the old library. What do I do from here?
musicmafia 38 Posted June 15, 2022 Author Posted June 15, 2022 1 minute ago, GrimReaper said: Under "Folders" section, remove old path(s)/add new path(s). ok will try that! 1
Solution GrimReaper 4851 Posted June 15, 2022 Solution Posted June 15, 2022 (edited) 3 minutes ago, musicmafia said: Is this the right location? It's showing the old library. What do I do from here? Right-click anywhere on library thumb or mouse hover left click three dot menu lower right corner>Edit. Edited June 15, 2022 by GrimReaper 1
musicmafia 38 Posted June 15, 2022 Author Posted June 15, 2022 That was quick, easy and painless!!! GrimReaper rocks! THANKS for your help! 1 1
