chef 3810 Posted June 14, 2022 Posted June 14, 2022 Hi @mofa2016, I think you might have posted this prior to trying out auto organize 2.0. @Luke I believe there may have been (or maybe still on going) issues with some of the providers. I'm seeing this error across the board. But we're keeping an eye on it. I'll let you know if thing change. 1 1
xlerate 9 Posted August 28, 2023 Posted August 28, 2023 On 6/14/2022 at 5:55 PM, chef said: Hi @mofa2016, I think you might have posted this prior to trying out auto organize 2.0. @Luke I believe there may have been (or maybe still on going) issues with some of the providers. I'm seeing this error across the board. But we're keeping an eye on it. I'll let you know if thing change. Has there been any update on this? I am seeing this more frequently using auto-organize where it will not resolve anything for a while then just start working.
Luke 42150 Posted August 28, 2023 Posted August 28, 2023 27 minutes ago, xlerate said: Has there been any update on this? I am seeing this more frequently using auto-organize where it will not resolve anything for a while then just start working. HI, it's best to look at a specific example: How to Report a Problem Thanks.
scharbag 19 Posted February 2, 2025 Posted February 2, 2025 (edited) I know this is an older topic but I have run into this a few times in the past. Was Auto Organizing a new series and 2 seasons worked great then it stopped working (I had 2 seasons in the sort folder and it worked - then added the next season in there and it failed). I have restarted Emby without fixing the issue. Here is a grep out of the logs showing the issue: 2025-02-02 09:02:08.798 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S05E19.mp4 2025-02-02 09:02:08.807 Info HttpClient: GET https://api4.thetvdb.com/v4/search?type=series&q=Highlander The Series 2025-02-02 09:02:08.836 Info TheMovieDb: MovieDbProvider: Finding id for item: Highlander The Series 2025-02-02 09:02:08.836 Info HttpClient: GET https://api.themoviedb.org/3/search/tv?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Highlander The Series&language=en-CA 2025-02-02 09:02:09.086 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S05E19.mp4 into series /mnt/HTPC/TV/Highlander The Series (1992) 2025-02-02 09:02:09.086 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S05E19.mp4 to new path /mnt/HTPC/TV/Highlander The Series (1992)/Season 5/Highlander The Series - s05e19 - The Modern Prometheus.mp4 2025-02-02 09:02:09.112 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S05E20.mp4 2025-02-02 09:02:09.125 Info HttpClient: GET https://api4.thetvdb.com/v4/search?type=series&q=Highlander The Series 2025-02-02 09:02:09.155 Info TheMovieDb: MovieDbProvider: Finding id for item: Highlander The Series 2025-02-02 09:02:09.155 Info HttpClient: GET https://api.themoviedb.org/3/search/tv?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Highlander The Series&language=en-CA 2025-02-02 09:02:09.470 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S05E20.mp4 into series /mnt/HTPC/TV/Highlander The Series (1992) 2025-02-02 09:02:09.471 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S05E20.mp4 to new path /mnt/HTPC/TV/Highlander The Series (1992)/Season 5/Highlander The Series - s05e20 - Archangel (1).mp4 2025-02-02 09:07:28.785 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E01.mp4 2025-02-02 09:07:28.798 Warn App: No provider metadata found for Highlander The Series season 6 episode 1 2025-02-02 09:07:28.799 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E02.mp4 2025-02-02 09:07:28.804 Warn App: No provider metadata found for Highlander The Series season 6 episode 2 2025-02-02 09:07:28.805 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E03.mp4 2025-02-02 09:07:28.811 Warn App: No provider metadata found for Highlander The Series season 6 episode 3 2025-02-02 09:07:28.813 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E04.mp4 2025-02-02 09:07:28.819 Warn App: No provider metadata found for Highlander The Series season 6 episode 4 2025-02-02 09:07:28.820 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E05.mp4 2025-02-02 09:07:28.827 Warn App: No provider metadata found for Highlander The Series season 6 episode 5 2025-02-02 09:07:28.828 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E06.mp4 2025-02-02 09:07:28.835 Warn App: No provider metadata found for Highlander The Series season 6 episode 6 2025-02-02 09:07:28.836 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E07.mp4 2025-02-02 09:07:28.843 Warn App: No provider metadata found for Highlander The Series season 6 episode 7 2025-02-02 09:07:28.844 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E08.mp4 2025-02-02 09:07:28.851 Warn App: No provider metadata found for Highlander The Series season 6 episode 8 2025-02-02 09:07:28.853 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E09.mp4 2025-02-02 09:07:28.859 Warn App: No provider metadata found for Highlander The Series season 6 episode 9 2025-02-02 09:07:28.861 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E10.mp4 2025-02-02 09:07:28.868 Warn App: No provider metadata found for Highlander The Series season 6 episode 10 2025-02-02 09:07:28.870 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E11.mp4 2025-02-02 09:07:28.877 Warn App: No provider metadata found for Highlander The Series season 6 episode 11 2025-02-02 09:07:28.878 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E12.mp4 2025-02-02 09:07:28.884 Warn App: No provider metadata found for Highlander The Series season 6 episode 12 2025-02-02 09:07:28.885 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E13.mp4 2025-02-02 09:07:28.890 Warn App: No provider metadata found for Highlander The Series season 6 episode 13 2025-02-02 09:07:42.332 Info App: Sorting file /mnt/HTPC/Downloading/TV_Sort/Highlander The Series S06E01.mp4 No idea why it just suddenly decided to stop working... Any thoughts on if this is just TheTVDB having a bit of a smoke break? Cheers, Edited February 2, 2025 by scharbag
scharbag 19 Posted February 2, 2025 Posted February 2, 2025 Bwahahahahaha - it just started working again... I guess there were some blockages in the internets for a minute. 1
