Jonathan1683 29 Posted June 14, 2022 Posted June 14, 2022 Hello I had to rebuild my server and I have notice sometimes I get like fan art when the good original is easily available in the identify tab, this wouldn't be a big deal, but I can't figure out how to change it other than manually uploading the images. If I go to identify it will find the good artwork it's usually either the only one shown or the first one, but when I click OK with replace image the server just spins indefinitely without changing the artwork. Maybe I am doing this wrong, if anyone has an idea how to change these let me know. Thank you,
Solution Happy2Play 9800 Posted June 14, 2022 Solution Posted June 14, 2022 All artwork is dependent on image downloader option per library not always the image that displays for Identify. You should be clicking Edit images on Identified media. But probably need to see server log to possibly see why you are getting infinite spinner.
Jonathan1683 29 Posted June 14, 2022 Author Posted June 14, 2022 Thanks I just noticed you can search for the images within the edit images tab, I didn't see any before and it works perfectly. 1
