revengineer 142 Posted June 14, 2022 Posted June 14, 2022 For me guide refresh fails at 15% as well. Error message is Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). at System.Guid.GuidResult.SetFailure(Boolean overflow, String failureMessageID) at System.Guid.TryParseExactD(ReadOnlySpan`1 guidString, GuidResult& result) at System.Guid.TryParseGuid(ReadOnlySpan`1 guidString, GuidResult& result) at System.Guid..ctor(String g) at MediaBrowser.Controller.Library.LibraryManagerExtensions.GetItemById(ILibraryManager manager, ReadOnlySpan`1 id) at MediaBrowser.Controller.Library.LibraryManagerExtensions.GetItemById(ILibraryManager manager, String id) at Emby.LiveTV.EmbyTV.RefreshTimers(CancellationToken cancellationToken, IProgress`1 progress) at Emby.LiveTV.LiveTvManager.RefreshChannels(IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)
Luke 42241 Posted June 14, 2022 Posted June 14, 2022 Hi @revengineer please attach the emby server log. Also have you done any going back and forth between 4.6 and 4.7?
ebr 16334 Posted June 14, 2022 Posted June 14, 2022 11 hours ago, Luke said: Hi @revengineer please attach the emby server log. Also have you done any going back and forth between 4.6 and 4.7?
Luke 42241 Posted June 14, 2022 Posted June 14, 2022 OK yes the going back and forth is likely the issue.
revengineer 142 Posted June 15, 2022 Author Posted June 15, 2022 22 hours ago, Luke said: Hi @revengineer please attach the emby server log. Also have you done any going back and forth between 4.6 and 4.7? Yes, I think the issue was "importing" the Live TV recording timers from 4.6.7 into 4.7.2 was the issue. After deleting these timer files, the guide refreshed fine. So this one is solved, but I am struggling with the audio sync issue, which is a real deal breaker. 1
vdrover 62 Posted July 24, 2024 Posted July 24, 2024 @revengineerSorry to bump an old thread: what do you mean by "deleting these timer files"?
sa2000 697 Posted July 26, 2024 Posted July 26, 2024 On 24/07/2024 at 22:07, vdrover said: Sorry to bump an old thread: what do you mean by "deleting these timer files I would guess it relates to the livetv data folder and the timers json files (adding context: link to new forum thread)
