DaveGibbon 1 Posted June 12, 2022 Posted June 12, 2022 Hi there , I've been using jriver with madvr for movies but it's so clunky. I went with emby theatre. I cannot find any settings for tone mapping HDR to sdr. When I do play the videos they definitely are way brighter then vlc (night and day ) but not nearly as good as madvr/mpc. I'm not sure if it's even tonemapping or vlc is just so crappy it looks better. Any help is appreciated. Thanks alot. Love the software layout. Everything is direct play. Thanks
Luke 42239 Posted June 13, 2022 Posted June 13, 2022 Hi there, what version of Emby Theater do you have installed?
DaveGibbon 1 Posted June 14, 2022 Author Posted June 14, 2022 Hey there, 3.0.15. I actually figured out how to use mpc-hc as an external player, using madvr as renderer. If I can't get It to tonemap correctly. This works as well. Thanks for quick reply ! 1
lifespeed 42 Posted July 2, 2022 Posted July 2, 2022 Can 3.0.15 play a 2160p HDR video to a 1080p SDR TV? Is any fiddling with settings required, or does it do the tone mapping automagically?
Luke 42239 Posted July 4, 2022 Posted July 4, 2022 On 7/1/2022 at 10:17 PM, lifespeed said: Can 3.0.15 play a 2160p HDR video to a 1080p SDR TV? Is any fiddling with settings required, or does it do the tone mapping automagically? Hi, it should work well out of the box. Have you given it a try?
