brianlam 11 Posted June 12, 2022 Posted June 12, 2022 (edited) SSA subtitle not sync to audio when resume, please check the demo video and log, thanks. Subtitle sync problem.wmv ffmpeg-remux-a6ff9872-dd76-4a30-bdbd-a39dfe1ddd9d_1.txt Edited June 12, 2022 by brianlam
Luke 42241 Posted July 2, 2022 Posted July 2, 2022 Hi, are you still seeing this with Emby Server 4.7.5?
visproduction 335 Posted July 12, 2022 Posted July 12, 2022 I don't see audio sync 100% correct in any of the playback. It's always a little off. I tried to sync it and it's off at the beginning around -540ms. What caused the frame rate on your .wmv screen video capture to be 25 fps? Did you set your screen capture to be 25fps for TV playback? The movie original on blu-ray is 1920x1080/24p SDR/BT.709 AVC-encoded DTS-HD Master. I see the blu-ray version includes DTS-HD Master audio. I wonder if that has something to do with the out of sync results after transcoding. Is the media in better sync when you play it with a 3rd party player like VLC? I think maybe your original has audio sync issues.
brianlam 11 Posted July 13, 2022 Author Posted July 13, 2022 Hi Luke, I found this problem only happen when video is direct play, if force the video to trans code, the subtitle get sync.
brianlam 11 Posted August 13, 2022 Author Posted August 13, 2022 On 8/6/2022 at 1:35 AM, Luke said: Hi, are you still having an issue with this? Yes, will help to fix it? doing anything for this?
