dmshimself 3 Posted June 11, 2022 Posted June 11, 2022 (edited) If I try to play a program that is being currently recorded via Live TV/Recordings then it always plays from the current time and I cannot get back to the beginning of the program with forward/back controls. If I happen to go to the same recording via My Media/Recordings, then it does correctly start playing from the beginning of the recording. This is with Apple TV app version 1.5.8 (19) and server version 4.7.2.0 Edited June 11, 2022 by dmshimself left server version off
Luke 42239 Posted June 16, 2022 Posted June 16, 2022 Hi there @dmshimself can we please look at an example? Thanks !
dmshimself 3 Posted June 16, 2022 Author Posted June 16, 2022 I'm not able to give you a recorded example, but the sequence I described reproduces the problem each time. Are you able to record anything and just follow those steps?
dmshimself 3 Posted June 17, 2022 Author Posted June 17, 2022 I could probably do a video of the TV screen with me running through the actions I've described if that would help?
Luke 42239 Posted July 23, 2022 Posted July 23, 2022 On 6/16/2022 at 10:14 PM, dmshimself said: I could probably do a video of the TV screen with me running through the actions I've described if that would help? No that's good, we'll take a look at it. Thanks.
rbknox 6 Posted April 26, 2023 Posted April 26, 2023 On Apple TV, I cannot even watch an active recording. When I go to play an active recording I get a dark screen with the name of the program and a spinning asterisk. Eventually the app crashes and returns to Apple TV Home screen.
Luke 42239 Posted May 13, 2023 Posted May 13, 2023 On 4/26/2023 at 12:59 PM, rbknox said: On Apple TV, I cannot even watch an active recording. When I go to play an active recording I get a dark screen with the name of the program and a spinning asterisk. Eventually the app crashes and returns to Apple TV Home screen. Hi, can you try the latest update to Emby for Apple TV and let us know how things compare? Thanks.
rbknox 6 Posted May 20, 2023 Posted May 20, 2023 On 5/12/2023 at 10:51 PM, Luke said: Hi, can you try the latest update to Emby for Apple TV and let us know how things compare? Thanks. I tried playing an active recording yesterday on Apple TV. If I hit the OK button, I still get the rotating busy asterisk and crash. If I hit Play it works fine. I had not tried the play button previously so can't comment on whether this is an improvement (I can say that ET Windows has been updated so that now hitting OK brings up a context menu during an active recording per my issue with ET Windows). Now that I can watch an Active recording on Apple TV, I can compare it to the experience on ET Windows. On Apple TV, left and right arrow clicks will advance or rewind the playback. On Windows, this can only be accomplished by using the +30, - 10 buttons below the timeline (i.e. arrows do not work properly in Windows). Also, neither Apple TV or Windows display a comprehendible timeline that provides information about where in the live recording one is currently at. Further, neither platform remembers where the playback is at. If you exit and return and choose Resume, playback still starts at the beginning. I have raised these issues previously in the ET Windows thread.
Luke 42239 Posted June 27, 2023 Posted June 27, 2023 On 5/20/2023 at 5:51 PM, rbknox said: I tried playing an active recording yesterday on Apple TV. If I hit the OK button, I still get the rotating busy asterisk and crash. If I hit Play it works fine. I had not tried the play button previously so can't comment on whether this is an improvement (I can say that ET Windows has been updated so that now hitting OK brings up a context menu during an active recording per my issue with ET Windows). Now that I can watch an Active recording on Apple TV, I can compare it to the experience on ET Windows. On Apple TV, left and right arrow clicks will advance or rewind the playback. On Windows, this can only be accomplished by using the +30, - 10 buttons below the timeline (i.e. arrows do not work properly in Windows). Also, neither Apple TV or Windows display a comprehendible timeline that provides information about where in the live recording one is currently at. Further, neither platform remembers where the playback is at. If you exit and return and choose Resume, playback still starts at the beginning. I have raised these issues previously in the ET Windows thread. Hi @rbknoxwe are working on improving this. Thanks for the feedback.
rbknox 6 Posted December 6, 2023 Posted December 6, 2023 On 6/27/2023 at 1:57 PM, Luke said: Hi @rbknoxwe are working on improving this. Thanks for the feedback. Hi, I just tried watching an active recording again on the Apple TV version of the app. Not sure anything has changed since my previous comments: - I still think selecting the recording using OK (Enter) is intuitive but this causes the Apple TV variant to have the spinning thing indefinitely (seems it no longer rashes the app). Pushing Play does start the app - there is no Resume if you exit the recording and attempt to re-enter. On windows there is a Resume which as noted elsewhere doesn’t work. Here you don’t even have the option - the Apple TV timeline is less confusing, though not sure it provides any more relevant information (as highlighted elsewhere per Windows Media Center and other recording apps, the timeline should show useful information like where you are in the recording, where the recording is at relative to live etc etc) - unlike the Windows variant, this one correctly allows skip forward and skip backwards (though the skip size in seconds is not a configurable option - one is stuck with 10s forward only). Of course right arrow left arrow is the only choice here versus Windows where there is that mode (which doesn’t work) and also the drop down +30 -10 buttons which is the only way to navigate in Windows). - this version also allows a speed ahead option (similar to streaming apps where you can accelerate +1, up to +4), which is not available in Windows. However, unlike most streaming apps, here you are forced to endure visual and audio chopping as the timeline speeds ahead - frenetic to say the least). Some sort of audio/video muting is required. Are any of these issues being addressed? Seems many are common to Apple TV and Windows (and other flavors?) Thanks
Luke 42239 Posted January 15, 2024 Posted January 15, 2024 HI, we are working on improving this. Thanks for reporting.
JonBo 1 Posted February 16, 2025 Posted February 16, 2025 Hi! I'm really enjoying Emby thus far and am really impressed with the work you have all done. Thanks! But I encounter this same problem. If I attempt to watch an M3U IPTV stream while it is being recorded the only option I have is the live stream--and I'm unclear as to whether it is sharing the stream or not. I can reproduce this when using Chrome or the FireTV app. On Chrome I'm asked if I want to start at the beginning or go to live--and both of them take me to live. On FireTV I'm not given an option and it takes me to live. When the recording is complete, it shows up in the recordings folder and I can watch it fine then. Of note, I can't see the recording in the recordings folder (on the apps) prior to completion. Can I provide you with any details or help debug this?
JonBo 1 Posted February 16, 2025 Posted February 16, 2025 Okay, weird update to this post. I can indeed access the recording and play it from the begining as long as I access the "Recordings" section from 'Home" and not via recordings under the Live-tv area. I think my issue can be withdrawn for now. I'll keep observing. 1
dmshimself 3 Posted February 16, 2025 Author Posted February 16, 2025 Yes I can also watch a live recording from the beginning if I remember to go to the recordings area. Trying to get guests and family members to remember to do this is not easy and it would be nice if this issue could be resolved.
