kitzuboss 1 Posted June 11, 2022 Posted June 11, 2022 Hello, This product (XTi 4144) works with emby and DSM 7.1-42661 (Synology NAS DS220+) ? VBox Android TV Gateway for Cable Model XTi 4144 for DVB-C The VBox Android TV Gateway is a hybrid quad-tuner running certified Android TV OS, merging online streaming services with Live broadcast TV, offering rich entertainment at home, to watch, record and recast your favorite channels on any device at home and on-the-go.This single box, streams local broadcast channels, from your Cable TV feed in broadcast-quality, allowing you to cut the cords without losing access to your favorite TV programming. https://vboxcomm.com/product/vbox-android-tv-gateway-for-cable/ Regards 1
Seger 123 Posted June 11, 2022 Posted June 11, 2022 Wasn't that a question? I'm also looking for a way to get cable TV into my Emby. Preferably with HD and so that several users can use it at the same time. I currently have a Diskstation, but it doesn't transcode. I keep reading about HDrun devices. I'm based in Germany, does anyone have any tips for me? Or was it not a question, but the device was already the solution? If so, how exactly do you record it in Emby? Thanks and best regards Seger
kitzuboss 1 Posted June 12, 2022 Author Posted June 12, 2022 (edited) I did a better search and found the Europe version of the site. You have 2 tunners and you can create m3u lists suported by emby. I will test it after i get it and i will post the result here. I bought with 140 Euro the following model: VBox TV Gateway for Cable - XTi 3452 from https://www.vboxcomm.eu/vbox-tv-gateway-for-cable-xti-3452/ This single box, equipped with 2 tuners, streams Cable TV programming up to 4K resolution, allowing you to cut the cords without losing access to your favorite broadcast programs. The VBox TV Gateway dual tuner records and streams content to multiple devices and channels simultaneously. For Germany version dvb-c you can try this website: https://www.vboxcomm.de/ Keep in mind, buy only dvb-c tunner if you have coaxial cable from tv providers. VBox XTi 3452 TV Gateway für DVB-C-Kabelfernsehen https://www.vboxcomm.de/vbox-tv-gateway-fur-dvb-c-kabelfernsehen-xti-3452/ VBox XTi 4144 Android TV Gateway für DVB-C-Kabelfernsehen https://www.vboxcomm.de/vbox-android-tv-gateway-fur-dvb-c-kabelfernsehen-xti-4144/ Edited June 12, 2022 by kitzuboss
kitzuboss 1 Posted June 12, 2022 Author Posted June 12, 2022 (edited) You can see the compare products on the following link: https://vboxcomm.com/products-comparison/ DVB-T = antena terestrial DVB-S = antena satellite DVB-C = cable coaxial (Europe) Edited June 12, 2022 by kitzuboss
kitzuboss 1 Posted June 12, 2022 Author Posted June 12, 2022 (edited) 13 hours ago, Seger said: Wasn't that a question? I'm also looking for a way to get cable TV into my Emby. Preferably with HD and so that several users can use it at the same time. I currently have a Diskstation, but it doesn't transcode. I keep reading about HDrun devices. I'm based in Germany, does anyone have any tips for me? Or was it not a question, but the device was already the solution? If so, how exactly do you record it in Emby? Thanks and best regards Seger Yeah, it was a question. I already bought the gateway version (dvb-c) and i will post the result here after testing. This product have up to 4k resolution on streaming. --------------------------------- I guess the following models are compatible with Emby (cable coaxial DVB-C for Europe): --------------- TECH4-2DT 2 tuners DVB-T/DVB-T2/DVB-C (unencrypted) 1 x RF/Cable in https://www.silicondust.com/product/tech4-2dt/ HDHomeRun CONNECT DUO • 2 tuner • DVB-T • DVB-T2 • DVB-C https://www.silicondust.com/product/hdhomerun-connect-duo/ HDHomeRun CONNECT QUATRO • 4 tuner • DVB-T • DVB-T2 • DVB-C https://www.silicondust.com/product/hdhomerun-connect-quatro/ Edited June 12, 2022 by kitzuboss
Seger 123 Posted June 12, 2022 Posted June 12, 2022 5 hours ago, kitzuboss said: Ja, es war eine Frage. Ich habe bereits die Gateway-Version (dvb-c) gekauft und werde das Ergebnis nach dem Testen hier posten. Dieses Produkt hat eine Streaming-Auflösung von bis zu 4k. --------------------------------- Ich denke, die folgenden Modelle sind mit Emby kompatibel (Kabel koaxial DVB-C für Europa): --------------- TECH4-2DT 2 Tuner DVB-T/DVB-T2/DVB-C (unverschlüsselt) 1 x HF/Kabeleingang https://www.silicondust.com/product/tech4-2dt/ HDHomeRun CONNECT DUO • 2 Tuner • DVB-T • DVB-T2 • DVB-C https://www.silicondust.com/product/hdhomerun-connect-duo/ HDHomeRun CONNECT QUATRO • 4 Tuner • DVB-T • DVB-T2 • DVB-C https://www.silicondust.com/product/hdhomerun-connect-quatro/ Very interesting thread and thanks for testing and sharing! I wonder though, do I also see the HD encrypted channels?
