dracon 0 Posted October 15, 2013 Posted October 15, 2013 HelloI have a problem with the MB Server. Every time I turn off the computer and turn it back to the MB Server I get an error:"Unhandled exceptiom: only allows one usage of each socket address (protocol / network address / port)"And the only way that works is reinstalled again the Server. The version I have installed is 3.0.5031.21343I have also installed the MB 2.thank you very much
CBers 7539 Posted October 15, 2013 Posted October 15, 2013 This message normally occurs when you are trying to start a 2nd instance of MB3 Server. Make sure you haven't got 2 MB3 trying to start up in the Startup folder. You may have one in ALL USERS and one in your USER.
Solution Luke 42171 Posted October 15, 2013 Solution Posted October 15, 2013 This can occur every now and then after restarting the server. Windows sometimes takes several minutes before it releases the ip bindings. either reboot or just wait five minutes.
dracon 0 Posted October 22, 2013 Author Posted October 22, 2013 Thanks for the answers, but I still have problems. Every time I restart the server I get errors. Now I get one and then the other behind.Unhandled exception: There was listen. Call Star method () before calling this method.Unhandled exception: Unable to access the deleted object. Object name: "System.Net.Sockets.Socket".The only way I have to fix it is to reinstall the MB3 Server every time you restart the computer.Any suggestions?thanks
