BlubberGuy 2 Posted June 10, 2022 Posted June 10, 2022 Hi, since the anidb recognition is bad I have switched, due to your recommendation, to TVDb for everything. My problem now is that TVDB does not have a lot of Genres/Tags like anidb has. However, I am filtering by Genres and now I get Anime mixed up with other Anime, which should not be together. Same with searching, quite infuriating to be unable to find Anime in Categories where they clearly belong to. Now, on the bottom of the Animesite are the Links to the other Sites... Is it somehow possible to scrap the stuff from anidb since it´s recognized in quite a lot of Anime anyway?
Luke 42186 Posted June 11, 2022 Posted June 11, 2022 Quote However, I am filtering by Genres and now I get Anime mixed up with other Anime, which should not be together. Same with searching, quite infuriating to be unable to find Anime in Categories where they clearly belong to. Hi there, can you please go over an example? Thanks !
