ivanrakic 2 Posted June 9, 2022 Posted June 9, 2022 I noticed a problem when "Play all from here" is used, chapter thumbnails won't show up (tried the regular way by clicking UP on the remote, which works fine when only one file is played - when regular "Play" is selected). Furthermore, Android TV application seems not supporting remote control keys "Channel UP/DOWN" for Next/Previous track, while regular Android app works just fine. Is that intentional, or a bug? *Latest Android TV version was tested 2.0.70 Thanks
ebr 16337 Posted June 9, 2022 Posted June 9, 2022 12 hours ago, ivanrakic said: I noticed a problem when "Play all from here" is used, chapter thumbnails won't show up Hi. Exactly where did you do this from?
ivanrakic 2 Posted June 9, 2022 Author Posted June 9, 2022 Android TV app 2.0.70 I have video files organized in separate folders, so when I play a single video in folder view, it works as expected (remote control UP brings up seek with chapter thumbnails), but when I select any video in the same folder and click on "Play all from here", remote control UP does bring seek, but no chapter thumbnails are there. I also noticed that if I play one of the files in certain folder, and then select another one and "Play all from here" when I reach the first one (I already played before), chapter thumbnails are there, but only for that specific video.
ebr 16337 Posted June 9, 2022 Posted June 9, 2022 Okay, so you are in folder view in a home video library and long-press on an item and select "Play from here"?
