poctum 0 Posted June 8, 2022 Posted June 8, 2022 Experiencing an issue when using AppleTV to play videos that require transcoding/remuxing. The source video has a DTS-HD MA audio track which will require transcoding to MP3 for the AppleTV and in the Emby Server logs I can see that it tries 115 or so times before finally transcoding the video. This is via local LAN with AppleTV set to 4K 120Mbps. If I set AppleTV Playback to 1080p 8Mbps, which is lower than the actual content, things work fine. I don't know when this stopped working since I normally use an Nvidia Shield, which is not experiencing this issue. I have tried switching between VAAPI and QSV with no change. I have disabled MPV in AppleTV which resolves this issue but causes stuttering issues. This was commented on in this article, which may be the same issue: Devices Not Having Issue: iPad Pro iPhone Pro Nvidia Shield Web Interface File Properties: Video Title 1080p HEVC Codec HEVC Profile Main 10 Level 120 Resolution 1920x1080 Aspect Ratio 16:9 Interlaced No Framerate 25 Bitrate 11.7 mbps Bit Depth 10 bit Pixel Format yuv420p10le Reference Frames 1 Audio Title English DTS-HD MA stereo (Default) Embedded Title DTS-HD Master Audio / stereo Language English Codec DTS Profile DTS-HD MA Layout stereo Channels 2 ch Sample Rate 48,000 Hz Bit Depth 16 bit Default Yes Date Issue Started: Unknown, maybe the recent IOS Update or the Emby app update I don't know when this stopped working since I normally use an Nvidia Shield, which is not experiencing this issue. Server Properties: OS: Ubuntu 20.04 LTS CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz (family: 0x6, model: 0x9e, stepping: 0x9) Emby Version: 4.7.2.0 - tired rolling back to 4.7.0.60 with same results. Log Files: https://1drv.ms/u/s!An41EjTwRiXuhZg72j_OE61H4HVrXg?e=8tjneE Timestamps: Select Play on AppleTV: 2022-06-08 10:01:10.186 Server Finally Transcodes: 2022-06-08 10:01:39.528
Luke 42241 Posted July 8, 2022 Posted July 8, 2022 HI, are you still having an issue with this with the Emby for Apple TV 1.6.0 app update?
poctum 0 Posted July 8, 2022 Author Posted July 8, 2022 @Luke AppleTV is 1.6.0 (1) and the issue still remains. Server is 4.7.5.0 4K HEVC HDR with Dolby Digital plays without issue. 4K HEVC HDR TrueHD/DTS only plays if transcoded (forced lower bitrate than the media, which switches to Dolby Digital) or with MPV disabled. Logs: https://1drv.ms/u/s!An41EjTwRiXuhZ8RpisX50WGSNgFOg?e=goIefb
Solution Luke 42241 Posted July 8, 2022 Solution Posted July 8, 2022 OK we're pushing out a 1.6.1 app update for another issue so please let me know if this helps with that. Thanks.
Coscast 0 Posted July 9, 2022 Posted July 9, 2022 Hi, A quick question about this, because i just installed emby again to test alternatives to plex. This issue here really annoys me. Why does emby even have to transcode when plex direct plays the same file ? This is a honest question, because i really want to get away from plex.
Seanmac6 5 Posted July 9, 2022 Posted July 9, 2022 2 hours ago, Coscast said: Hi, A quick question about this, because i just installed emby again to test alternatives to plex. This issue here really annoys me. Why does emby even have to transcode when plex direct plays the same file ? This is a honest question, because i really want to get away from plex. if you having yet i would recommend infuse firecore it is a good alternative for plex and emby and a great video player too until plex and emby update their video player to the apple tv native player infuse is what i will be using and don't get me started on jellyfin smh lol
poctum 0 Posted July 9, 2022 Author Posted July 9, 2022 AppleTV app 1.6.1 has resolved my issues. Thank you, @Luke.
ellisd4 78 Posted July 10, 2022 Posted July 10, 2022 (edited) 19 hours ago, poctum said: AppleTV app 1.6.1 has resolved my issues. Thank you, @Luke. I can actually play HEVC content with MPV now too! Before it just pretended to load. Super excited about this! I don’t like remuxing my blu ray rips. However, when played Emby now gives the green artifacts (attached). Changing the audio track to stereo doesn’t fix it, but adding subtitles which forces transcoding works. The subtitles take up the whole screen. Any thoughts? Edited July 10, 2022 by ellisdustin Add mpv info
vdatanet 1619 Posted July 11, 2022 Posted July 11, 2022 @ellisdustin Can you post your ffmpeg log? The server dashboard is not accurate, it's showing this: But it's doing this: 09:01:16.464 Stream #0:0 -> #0:0 (copy) 09:01:16.464 Stream #0:2 -> #0:1 (dts (dca) -> ac3 (native)) I was excited to see direct playback of DTS (decoding at client side) but the dashboard was not correct.
ellisd4 78 Posted July 11, 2022 Posted July 11, 2022 6 hours ago, Luke said: Hi, what format subtitles is that? PGSSUB - BluRay Rip. Thanks!
ellisd4 78 Posted July 11, 2022 Posted July 11, 2022 4 hours ago, vdatanet said: @ellisdustin Can you post your ffmpeg log? The server dashboard is not accurate, it's showing this: But it's doing this: 09:01:16.464 Stream #0:0 -> #0:0 (copy) 09:01:16.464 Stream #0:2 -> #0:1 (dts (dca) -> ac3 (native)) I was excited to see direct playback of DTS (decoding at client side) but the dashboard was not correct. My ffmpeg log is attached along with Emby Server log. ffmpeg-directstream-ab3d9347-28c9-4948-a659-4a76da6cd5ca_1.txt embyserver (6).txt ffmpeg-transcode-75dcd2b7-9de9-4b04-9ae3-df20b703b045_1.txt
Luke 42241 Posted July 13, 2022 Posted July 13, 2022 On 7/11/2022 at 7:44 AM, ellisdustin said: My ffmpeg log is attached along with Emby Server log. ffmpeg-directstream-ab3d9347-28c9-4948-a659-4a76da6cd5ca_1.txt 308.88 kB · 2 downloads embyserver (6).txt 3.8 MB · 0 downloads ffmpeg-transcode-75dcd2b7-9de9-4b04-9ae3-df20b703b045_1.txt 71.62 kB · 0 downloads If you play the same content in the web app with the subtitles selected and the server transcoding, how does that compare?
ellisd4 78 Posted July 14, 2022 Posted July 14, 2022 19 hours ago, Luke said: If you play the same content in the web app with the subtitles selected and the server transcoding, how does that compare? Oddly enough, if I play in the web app, the subtitles are huge as well, but in iOS they look perfect. However, in the web app I can force transcoding by adjusting the quality and the video plays fine without subs. On Apple TV I cannot do that so the only way to force transcoding is adding in the subs.
Luke 42241 Posted August 18, 2022 Posted August 18, 2022 On 7/14/2022 at 8:21 AM, ellisdustin said: Oddly enough, if I play in the web app, the subtitles are huge as well, but in iOS they look perfect. However, in the web app I can force transcoding by adjusting the quality and the video plays fine without subs. On Apple TV I cannot do that so the only way to force transcoding is adding in the subs. hi @ellisdustin are you still having an issue with this?
ellisd4 78 Posted August 18, 2022 Posted August 18, 2022 (edited) 15 minutes ago, Luke said: hi @ellisdustin are you still having an issue with this? Hey @Luke, Thanks for checking in. I've temporarily switched back over to Plex until the Apple Silicon release is ready. I jumped the gun and purchased the lifetime pass and switched all my users over without fully testing everything out (transcoding which only seems to be SW on my M1, apps, etc). Unfortunately (I say this because the Apple Framework seems like a curse sometimes) my house is all Apple, including the streaming clients. Once the Apple Silicon release is available, I'll reintroduce to the fam. Edited August 18, 2022 by ellisdustin missing words
