dyecast 6 Posted March 27, 2022 Posted March 27, 2022 If I listen or watch remote, it works. see attached. Works for my PC and Roku on the LAN just fine.
dyecast 6 Posted March 27, 2022 Author Posted March 27, 2022 I have uninstalled and reinstalled the iOS app and fully restarted the Emby server. No change.
Luke 42241 Posted March 28, 2022 Posted March 28, 2022 Hi there @dyecast, can we please look at an example? Thanks !
dyecast 6 Posted April 10, 2022 Author Posted April 10, 2022 I posted a screenshot of the error. Occurred on iPad, iPhone 11 and iPhone 13 Pro Max. All iOS 15.4.1.
Luke 42241 Posted April 11, 2022 Posted April 11, 2022 @dyecast can you please attach the information that I've requested in my link above? Thanks !
ich777 11 Posted June 8, 2022 Posted June 8, 2022 Hi, I'm experiencing a weird issue on my iOS device (iPhone Xs, iOS15.5) with the latest version from Emby. If I'm in me LAN/WLAN and try to play some media it simply doesn't work and it says that no stream is available, however if I'm connecting from outside my network (WAN) everything is working as expected. Is there some way to debug this on my Phone? Please note that this is only the case on my iPhone and on all other devices on my network it works as expected (Web Browser, Android,...) and I'm connecting with my domain name to Emby, so hair pin NAT is not the issue. Thank you in advance.
Luke 42241 Posted June 8, 2022 Posted June 8, 2022 Hi there, can we please look at an example? Thanks.
ich777 11 Posted June 10, 2022 Posted June 10, 2022 (edited) On 6/8/2022 at 9:25 PM, Luke said: Hi there, can we please look at an example? Sorry for the delayed response... I've now attached the server log and also the embyserver.txt where you can see that I've tried to start a stream at around 7:17 from my LAN which actually repeats over and over because the Emby tells me that there is no stream available when I click OK then the message appears again in the app and so on until I close the app. As said above all other clients in my LAN work as expected with my domain name (Android, Windows, Linux,...). No that I'm talking about that, IIRC if I'm trying to download files to my iPhone I think that even this is working from my LAN but I'm not sure about that and have to test that when I got home. embyserver.txt embyserver-63790416000.txt Edited June 10, 2022 by ich777
dyecast 6 Posted June 10, 2022 Author Posted June 10, 2022 Sorry for not getting back sooner. I just generated the error and attached is the only one of the logs that updated its TimeStamp afterwards. 2022-06-10 @ 12:15pm was when I generated the error on my iPhone. embyserver.txt
dyecast 6 Posted June 10, 2022 Author Posted June 10, 2022 I had been watching several shows remotely today over the WAN where Emby has to transcode. Video is good. Audio is good. When I'm on my LAN, neither music nor videos work. Weird.
dyecast 6 Posted June 10, 2022 Author Posted June 10, 2022 Just upgraded Emby on my Synology to v.4.7.2. No change.
dyecast 6 Posted June 10, 2022 Author Posted June 10, 2022 See attached attempt to play audio and another attempt to play video. RPReplay_Final1654890064.mp4 RPReplay_Final1654890012.mp4
JoshL 19 Posted June 12, 2022 Posted June 12, 2022 If you go into settings, do you have the Local Network permission turned on for Emby? 1 1
Solution Luke 42241 Posted June 12, 2022 Solution Posted June 12, 2022 2 minutes ago, JoshL said: If you go into settings, do you have the Local Network permission turned on for Emby? He's referring to the iOS local network permission to grant the Emby app local network access. This is a requirement and the permission prompt is part of the install but you may have inadvertently restricted it. See here to learn how to check this: https://macreports.com/local-network-access-on-iphone-what-it-is-and-how-to-enable-it/ Let us know if this helps. Thanks. 1
ich777 11 Posted June 12, 2022 Posted June 12, 2022 49 minutes ago, JoshL said: If you go into settings, do you have the Local Network permission turned on for Emby? 45 minutes ago, Luke said: He's referring to the iOS local network permission to grant the Emby app local network access. This is a requirement and the permission prompt is part of the install but you may have inadvertently restricted it. Thank you both! Now I'm thinking that iOS is stupid sometimes... 1
dyecast 6 Posted June 15, 2022 Author Posted June 15, 2022 On 6/12/2022 at 11:32 AM, Luke said: He's referring to the iOS local network permission to grant the Emby app local network access. This is a requirement and the permission prompt is part of the install but you may have inadvertently restricted it. See here to learn how to check this: https://macreports.com/local-network-access-on-iphone-what-it-is-and-how-to-enable-it/ Let us know if this helps. Thanks. Fixed it for me. Feeling REALLY dumb. It’s the little things. 1
