ax1977 1 Posted June 8, 2022 Posted June 8, 2022 For some weeks I've been experiencing some channels default to the SAP audio stream even though the audio selection is set to the primary English stream. I have to set it to the SAP stream to get the primary stream. The first couple of seconds after tuning into the channels the audio is correct but then switches. The is happening on the Emby app for Fire TV and Android but doesn't happen watching on my web browser. I last tune into channel 737 at 9:45p today Also I'm seeing some serious lip sync issues. My tuner is a HDHomerun Prime embyserver.txt
Luke 42243 Posted June 15, 2022 Posted June 15, 2022 Hi there, can you please try side loading our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks.
ax1977 1 Posted June 19, 2022 Author Posted June 19, 2022 On 6/15/2022 at 8:39 AM, Luke said: Hi there, can you please try side loading our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks. Ok. I installed the android app on my fire stick and am still seeing the same issues. Also closed captioning doesn't work.
Luke 42243 Posted July 2, 2022 Posted July 2, 2022 Hi @ax1977 are you still having an issue with this? Have you updated to Emby Server 4.7.5?
ax1977 1 Posted July 2, 2022 Author Posted July 2, 2022 3 hours ago, Luke said: Hi @ax1977 are you still having an issue with this? Have you updated to Emby Server 4.7.5? Yes I have updated to 4.7.5 and yes I'm still having the same issue
Luke 42243 Posted August 19, 2022 Posted August 19, 2022 @ax1977 have you tried this with Emby Server 4.7.6?
ax1977 1 Posted August 19, 2022 Author Posted August 19, 2022 3 hours ago, Luke said: @ax1977 have you tried this with Emby Server 4.7.6? Yes. The issue persists.
Luke 42243 Posted September 1, 2022 Posted September 1, 2022 Are you still having an issue with this now?
ax1977 1 Posted September 1, 2022 Author Posted September 1, 2022 8 hours ago, Luke said: Are you still having an issue with this now? Yes.
