Jonathan1683 29 Posted June 7, 2022 Posted June 7, 2022 Hello, I just noticed that "missing Episode" does not show for normal users, is there a permissions thing I can change so users know when there are missing episodes so they can notify me if needed? Thank you,
Solution Luke 42186 Posted June 7, 2022 Solution Posted June 7, 2022 HI, make sure they have it enabled in their user profile options.
Jonathan1683 29 Posted June 9, 2022 Author Posted June 9, 2022 Thanks luke is there a way to force this option for everyone without requiring them all to change it manually?
Luke 42186 Posted June 9, 2022 Posted June 9, 2022 9 hours ago, Jonathan1683 said: Thanks luke is there a way to force this option for everyone without requiring them all to change it manually? Hi, there is no way to do that, sorry. 1
