purger500 13 Posted December 18, 2022 Posted December 18, 2022 On 12/12/2022 at 12:09 PM, rbjtech said: I don't use the Android App (and won't until it's fully functional and 'released') - but on AndroidTV App and the Shield 2019 Pro - I have never had any issues resuming DTS-HD..nor ff or rewinding ? I think the 'handshake' between the devices plays a large part in this - some devices seem to 'recover' better (I use a Denon AVR for example), while other devices struggle and need a resync. The other aspect might be that the player is needing to extract the DTS Core from the DTS-HD because it can't natively play it - and it is this process where it is failing. I use Denon also, X3800H. My sistem is capable for any audio format and 4k HDR and DV video.
Luke 42245 Posted January 9, 2023 Posted January 9, 2023 On 12/18/2022 at 2:07 PM, purger500 said: Hi Luke, yes, problem is still present. @purger500 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
lukeholderness 0 Posted April 7, 2023 Posted April 7, 2023 I have the same problem - been ignoring it for a while but more DTS releases make this a more pressing matter. Sideloading the standard android app makes no difference for me. The error is stuttering when resuming any files with DTS audio. A quick rewind makes it work but can't see why this is happening. Works find in Jellyfin...
Jam_Lai 1 Posted April 11, 2023 Posted April 11, 2023 On 1/9/2023 at 10:55 AM, Luke said: @purger500 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. I had the same issue when I'm playing mkv with DTS-HD files...it's very laggy I tried the standard android, everything works fine~~ I can play mkv with trueHD, atmos, DTS-HD bitstream to amp perfectly.
Luke 42245 Posted April 14, 2023 Posted April 14, 2023 On 4/11/2023 at 5:27 AM, Jam_Lai said: I tried the standard android, everything works fine~~ I can play mkv with trueHD, atmos, DTS-HD bitstream to amp perfectly. Great, thanks. Are you happy continuing to use that?
Jam_Lai 1 Posted April 14, 2023 Posted April 14, 2023 2 hours ago, Luke said: Great, thanks. Are you happy continuing to use that? it's ok, of course, android tv verison is preferable? I'm not sure, but I'm happy with android version
lukeholderness 0 Posted April 16, 2023 Posted April 16, 2023 It doesn’t matter which version of Emby I use the problem persists. Works fine on my Apple TV but not my shield.
Jam_Lai 1 Posted April 16, 2023 Posted April 16, 2023 On 4/14/2023 at 6:06 PM, Jam_Lai said: it's ok, of course, android tv verison is preferable? I'm not sure, but I'm happy with android version as I just finished the traditional chinese translation of android tv app
Jam_Lai 1 Posted April 16, 2023 Posted April 16, 2023 36 minutes ago, lukeholderness said: It doesn’t matter which version of Emby I use the problem persists. Works fine on my Apple TV but not my shield. My shield is ok, but it doesn't work fine on my apple tv, when I tried to play Dolby vision 4K mkv....it can't play..
