Guest Posted June 6, 2022 Posted June 6, 2022 Hi, Lately when Emby tried to refresh the guide it'll max the memory on the server. It won't download the new guide data. It has crashed the windows PC because its using so much resources, becasue of this resource drain its impossible to use clients. the schedule it to update the guide at midnight, the only way to stop this is to restart the server. However at the following midnight it'll restart the process. I've server logs attached. can you help please? embyserver-63790101350.txt embyserver.txt
Luke 42241 Posted June 6, 2022 Posted June 6, 2022 Hi there, I don't see anything obvious here. did you allow the guide refresh process to finish?
Guest Posted June 6, 2022 Posted June 6, 2022 Hi, No I didn't but It was running for about 10 hours, using 90% of available PC ram which was about 4Gb. I had to reboot the PC as it was unresponsive due to the resources refreshing the guide was requiring. It seemed stuck at 15% progress.
Guest Posted June 14, 2022 Posted June 14, 2022 No it hasn't. It crashes my machine and is always stuck at 15%. This is a new issue as for several months it worked fine. The TV guide did update quickly and didn't hog the machines resources so I never noticed it before.
Luke 42241 Posted July 3, 2022 Posted July 3, 2022 Hi @dermotspillane are you still having an issue with this? Have you updated to Emby Server 4.7.5?
Guest Posted July 10, 2022 Posted July 10, 2022 Hi Luke. This Issue was resolved when it was upgraded. Thanks.
RIP314 2 Posted June 2, 2024 Posted June 2, 2024 (edited) just did a clean install yesterday and now the guide won't refresh after using VirtualTV plugin to make a couple channels. it just gets stuck at 15% Edited June 2, 2024 by RIP314
pünktchen 1411 Posted June 2, 2024 Posted June 2, 2024 34 minutes ago, RIP314 said: just did a clean install yesterday and now the guide won't refresh after using VirtualTV plugin to make a couple channels. it just gets stuck at 15% Do all the channels show something in the channel preview of the plugin settings?
RIP314 2 Posted June 2, 2024 Posted June 2, 2024 (edited) do you mean in the settings when you create a channel you can hit the preview option before save? or do you mean does it show the channels listed in the virtualtv settings? THe first one is no, it won't produce a preview and when I try to view the channel from the guide it just plays 1minute of blank screen cycled over and over. It does show up as a channel that I can edit in the virtualtv settings. PS i uninstalled virtualtv and the guide refreshed fine, but once i reinstalled i had the same problem. Edited June 2, 2024 by RIP314
pünktchen 1411 Posted June 2, 2024 Posted June 2, 2024 1 minute ago, RIP314 said: do you mean in the settings when you create a channel you can hit the preview option before save? Yes. 1 minute ago, RIP314 said: THe first one is no, it won't produce a preview And there's the problem. Please post some screenshots of the channel conditions for one of your channels that doesn't generate a preview.
RIP314 2 Posted June 2, 2024 Posted June 2, 2024 as you can see I rolled back to a previous build of VirtualTv as a troubleshooting measure, but the settings and issues were the same with the newest version as well.
RIP314 2 Posted June 2, 2024 Posted June 2, 2024 thanks, i really love this plugin when I can get it to function
RIP314 2 Posted June 2, 2024 Posted June 2, 2024 Another example that doesn't work. I can't get anything with the studio rules to work, I'm not familiar with logic operators so maybe that's where I messing something up.
pünktchen 1411 Posted June 2, 2024 Posted June 2, 2024 1 hour ago, RIP314 said: Another example that doesn't work. I can't get anything with the studio rules to work, I'm not familiar with logic operators so maybe that's where I messing something up. Parentheses are used to group logical operators, so (WWF) makes trouble. What you could do here is: World Wrestling Federation*
RIP314 2 Posted June 2, 2024 Posted June 2, 2024 15 minutes ago, pünktchen said: Parentheses are used to group logical operators, so (WWF) makes trouble. What you could do here is: World Wrestling Federation* Yes! That worked, and now for some bizarre reason the first channel I showed you as example seems to be working as well. I did upgrade back to the latest build before sending you the second example Idk if that had some effect on the first example.
pünktchen 1411 Posted June 2, 2024 Posted June 2, 2024 Conclusion: Always test your channels with the preview button. If it does not work, ask for help.
RIP314 2 Posted June 2, 2024 Posted June 2, 2024 is there a way to play from a specific folder if that folder itself is not a library? I know I can turn the items from folder into a collection of playlist, but I was interested in a way to play just from a specific folder.
pünktchen 1411 Posted June 2, 2024 Posted June 2, 2024 No that's not possible. I would go the playlist route because of its user permissions.
