evox 7 Posted June 5, 2022 Posted June 5, 2022 hello guys, i'm running emby on ubuntu server and tried the ARD Mediathek plugin but after some days i uninstalled but after any emby reboot the plugin shows as installed and i can't remove it. any ideas to delete permanently?
Solution Luke 42246 Posted June 6, 2022 Solution Posted June 6, 2022 Hi @evox, the emby server log file will contain the plugins path. Try just deleting the .dll files for those plugins manually. Please let us know if this helps. Thanks.
evox 7 Posted June 10, 2022 Author Posted June 10, 2022 thanks for the idea, just worked doing sudo rm /var/lib/emby/plugins/Emby.Plugin.Ard.dll 1
