iam4uk 26 Posted September 30, 2014 Posted September 30, 2014 MB Server Version 3.0.5366.22005 MB Classic Version 3.0.213.0 MB Intros Version 1.0.3.2 New internal player interface selected within MBC configuration. Files for movies and television shows and trailers/intros in MKV containers, with just a few MP4. Without MB Intros "active," the new internal player interface shows and functions. With MB Intros "active," the new internal player interface will not show up, it reverts to the WMC interface. Ideas about such behavior?
ebr 16344 Posted September 30, 2014 Posted September 30, 2014 Only the intros themselves should play in the wmc interface. The actual item will follow your settings.
iam4uk 26 Posted September 30, 2014 Author Posted September 30, 2014 ebr, your statement matches my understanding of how it should be. However, that is not how it is. The actual item (movie, TV episode) plays after the intros, but does not follow my settings regarding the new player interface. Having the new player interface selected results in the new player interface being usable when MB Intros is not applied to the profile; having the new player interface selected results in the old WMC interface being used for the actual item (movie, TV episode) whenever MB Intros is applied to the profile.
ebr 16344 Posted September 30, 2014 Posted September 30, 2014 Yeah, I think it is a timing thing. Some may work and others won't. I can adjust it a bit but the effect is probably going to be a flash of the details screen between intros and the main feature.
iam4uk 26 Posted September 30, 2014 Author Posted September 30, 2014 That makes sense. Between the intro and feature, there is a split-second of background image (not actually long enough to see if it is the details screen).
