stevesb99 1 Posted June 4, 2022 Posted June 4, 2022 I just updated to ET 3.0.15 and I can no longer play video files (SD,HD,BluRay,4K HDR, 3D etc.) with MPC-HC64 as an external player. VLC works fine though. I've used MPC-HC64 for years with no problem until the recent ET update. I have the Emby client on my Win 10 HTPC and Emby Server 4.7.2.0 on my Qnap NAS. Can anyone help. Thanx.
Luke 42239 Posted June 6, 2022 Posted June 6, 2022 Hi there @stevesb99 what exactly happens when you try?
stevesb99 1 Posted June 6, 2022 Author Posted June 6, 2022 (edited) Luke, it just plays the video with the built-in player, which is I guess mpv. This never happened before the ET 3.0.15 update. MPC-HC64 would always be the player used as I pointed to it in the settings in Emby Theater. And like I said VLC works fine as an external player, so I'm perplexed. Edited June 6, 2022 by stevesb99
stevesb99 1 Posted June 6, 2022 Author Posted June 6, 2022 Okay. I had updated MPC-HC64 just recently to the current version. On a whim I downloaded the version as of 06/2020 and installed it as the external player and it works fine! I guess the newest version of ET just doesn't like the newest version of MPC-HC64. Crisis over...............................................................................................for now.
