chef 3811 Posted December 9, 2022 Author Posted December 9, 2022 (edited) 10 hours ago, slevin7 said: I think I found the problem . I had the same problem again today. So one item is recognized, the other not so right and from the process status both do not come out... I have apparently with some items 2 entries in the database (here with test files simulated). Therefore the autoorganizer is confused, as I am. Can I get rid of the duplicate entries somehow? I have seen this before. You could try and vaccume the database from the Database tab. Or try to determine which entry is the correct one, and use smart lists to point those items t77o the correct location. Let me know how it goes. This has happened to me before.q @slevin7 is superman part of top picks ? Edited December 9, 2022 by chef
Stellarat 12 Posted December 9, 2022 Posted December 9, 2022 4 minutes ago, chef said: Does the # mean something when using Synology? Or maybe two ## together mean something to the operating system? Not as far as I know, but I'm no Linux or DSM expert. This is a new setup on a Synology NAS so it is the only series I have added so far. I found that the incomplete downloads folder was a sub folder of the watched folder which wasn't what I intended. So I moved it and reran the specific show. This time it completed without saying "File In Use". However no flag file was created. On a subsequent autorun this file was created in the root of downloads: Slow.Horses.S02E01.Last.Stop.1080p.ATVP.WEBRip.DDP5.1.x264-NTb[TGx]\####emby.extracted#### I'll try another series and see what happens.
Stellarat 12 Posted December 9, 2022 Posted December 9, 2022 (edited) deleted Edited December 9, 2022 by Stellarat
chef 3811 Posted December 9, 2022 Author Posted December 9, 2022 59 minutes ago, Stellarat said: Not as far as I know, but I'm no Linux or DSM expert. This is a new setup on a Synology NAS so it is the only series I have added so far. I found that the incomplete downloads folder was a sub folder of the watched folder which wasn't what I intended. So I moved it and reran the specific show. This time it completed without saying "File In Use". However no flag file was created. On a subsequent autorun this file was created in the root of downloads: Slow.Horses.S02E01.Last.Stop.1080p.ATVP.WEBRip.DDP5.1.x264-NTb[TGx]\####emby.extracted#### I'll try another series and see what happens. Oh! Did I not make extraction task look recursively through the watched folder?? I had better pull up the solution. I have three massive projects on the go (which is great but...) my list of bugs is growing fast. It's a bit hard to keep up.
MrBronte 3 Posted January 21, 2023 Posted January 21, 2023 Hi, the "%sn" pattern for season name in the season pattern directory doesn't work, can it be fixed or it's on purpose? Thanks!
chef 3811 Posted January 22, 2023 Author Posted January 22, 2023 12 hours ago, MrBronte said: Hi, the "%sn" pattern for season name in the season pattern directory doesn't work, can it be fixed or it's on purpose? Thanks! I'll take a look. I think you can use '%s', or '%0s' if you want season numbers up to 9 to named '01', '02' etc. So for example: 'S%s' will resolve to 'S1', and 'S%0s' will resolve to 'S01'. But I will double check that.
Grumpy1 46 Posted January 27, 2023 Posted January 27, 2023 does anyone have any issues when there is a year in the title ? ie- Poker face (2023) i seem to be getting Attention unidentified on these types lately loving this plugin ...shame i never noticed earlier 1
ginjaninja 605 Posted January 27, 2023 Posted January 27, 2023 @chef thanks for the plugin , getting back into again now im on release server. would you consider making the default movie edition be none rather than "theatrical". and including the " - " of " - %e" in the token....so if no movie edition is detected, no " - " string is generated? editions in Emby naming scheme have to be prefixed " - " so i dont think anything is lost making it part of the %e token...and that way if no movie edition is detected the resultant filename will still be consistent/good..with a movie pattern of eg %mn (%my)%e.%ext. the plugin is making all my organised movies look like the theatrical edition when it fact the edition is unknown and not specified. thanks for considering 1
chef 3811 Posted January 27, 2023 Author Posted January 27, 2023 23 minutes ago, ginjaninja said: @chef thanks for the plugin , getting back into again now im on release server. would you consider making the default movie edition be none rather than "theatrical". and including the " - " of " - %e" in the token....so if no movie edition is detected, no " - " string is generated? editions in Emby naming scheme have to be prefixed " - " so i dont think anything is lost making it part of the %e token...and that way if no movie edition is detected the resultant filename will still be consistent/good..with a movie pattern of eg %mn (%my)%e.%ext. the plugin is making all my organised movies look like the theatrical edition when it fact the edition is unknown and not specified. thanks for considering Sure thing. All sounds good to me. 2
Frago21ps 3 Posted February 6, 2023 Posted February 6, 2023 hi from greece,how can i install it on synology 7?file explorer can go to emby data folder
GrimReaper 4909 Posted February 6, 2023 Posted February 6, 2023 7 minutes ago, Frago21ps said: hi from greece,how can i install it on synology 7?file explorer can go to emby data folder 1
markdalen 0 Posted February 11, 2023 Posted February 11, 2023 I am getting "File in use" errors on every file. Not running any torrent client and the file is not being accessed anywhere else. Server is running on my Nvidia Shield and files are located on a wired external drive connected to the shield. My log has the same error that was mentioned previously: AutoOrganize: Auto-organize Path is locked by other processes. Please try again later. Any help?
Luke 42252 Posted February 12, 2023 Posted February 12, 2023 6 hours ago, markdalen said: I am getting "File in use" errors on every file. Not running any torrent client and the file is not being accessed anywhere else. Server is running on my Nvidia Shield and files are located on a wired external drive connected to the shield. My log has the same error that was mentioned previously: AutoOrganize: Auto-organize Path is locked by other processes. Please try again later. Any help? Usually it means that auto-organize is trying to move a file that is still in process of being downloaded.
markdalen 0 Posted February 12, 2023 Posted February 12, 2023 15 hours ago, Luke said: Usually it means that auto-organize is trying to move a file that is still in process of being downloaded. Files are already completely downloaded, so I don't think that is the case. Also, the older Auto Organize plugin from the catalog works without this error, so I think it might be something with this new version
Luke 42252 Posted February 12, 2023 Posted February 12, 2023 1 hour ago, markdalen said: Files are already completely downloaded, so I don't think that is the case. Also, the older Auto Organize plugin from the catalog works without this error, so I think it might be something with this new version Ok I would suggest attaching the emby server log for @chef to review.
chef 3811 Posted February 12, 2023 Author Posted February 12, 2023 Sorry guys!, it has been busy! But I am here, and the Auto organize plus plugin does need some love. I think we need to strip back on some features. We should find out what is working and what is not, now that it has been used in the wild. I know that the preprocessing part is a useful addition, but has its kinks. The UI also has some useful parts, but perhaps we can streamline the logic a bit. Sounds like, the "file in use" state needs to be looked at. We use a file stream object to attempt to access the file, if the file can be accessed at the time act on it. I will look at that particular code first. 1
GiGo 108 Posted April 3, 2023 Posted April 3, 2023 Hi @chefhope all is well with yourself, I was wondering where you have gotten to with this wonderful plugin? Hoping some of the kinks have been ironed out? Keep up the good work 1
daedalus 434 Posted July 4, 2023 Posted July 4, 2023 no fixes for months neither for stable nor beta version for beta of the server is completly broken again next dev has left this "project" and this can be considered dead, again this thing is cursed to hell
Grumpy1 46 Posted July 4, 2023 Posted July 4, 2023 yeah i couldn't get the beta version working any longer so i just wenet back to using Filebot 1
daedalus 434 Posted July 8, 2023 Posted July 8, 2023 did the same now plugin uninstalled and topic unsubscribed
Luke 42252 Posted July 8, 2023 Posted July 8, 2023 The version in the catalog is still actively supported.
AdrianW 1058 Posted August 7, 2023 Posted August 7, 2023 4.8.0.40 has finally broken this version of Auto Organise - it won't even run at all now. At least up until yesterday it would sort episodes for me. I've rolled back to 1.6.6.0 and it's still not working - here's the appropriate section from the log: *** Error Report *** Version: 4.8.0.40 Command line: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: C:/Users/Adrian/AppData/Roaming/MediaBrowser-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server Application path: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\system System.MissingMethodException: System.MissingMethodException: Method not found: 'Void SQLitePCL.pretty.IBindParameter.Bind(System.ReadOnlySpan`1<Char>)'. at Emby.AutoOrganize.Data.SqliteExtensions.TryBind(IStatement statement, String name, String value) at Emby.AutoOrganize.Data.SqliteFileOrganizationRepository.<>c__DisplayClass3_0.<SaveResult>b__0(IDatabaseConnection db) at SQLitePCL.pretty.DatabaseConnection.<>c__DisplayClass18_0.<RunInTransaction>b__0(IDatabaseConnection db) at SQLitePCL.pretty.DatabaseConnection.RunInTransaction[T](IDatabaseConnection This, Func`2 f, TransactionMode mode) at SQLitePCL.pretty.DatabaseConnection.RunInTransaction(IDatabaseConnection This, Action`1 action, TransactionMode mode) at Emby.AutoOrganize.Data.SqliteFileOrganizationRepository.SaveResult(FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganizationService.SaveResult(FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.EpisodeFileOrganizer.OrganizeEpisodeFile(String path, TvFileOrganizationOptions options, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.TvFolderOrganizer.Organize(TvFileOrganizationOptions options, CancellationToken cancellationToken, IProgress`1 progress) Source: Emby.AutoOrganize TargetSite: Void TryBind(SQLitePCL.pretty.IStatement, System.String, System.String)
Luke 42252 Posted August 7, 2023 Posted August 7, 2023 5 hours ago, AdrianW said: 4.8.0.40 has finally broken this version of Auto Organise - it won't even run at all now. At least up until yesterday it would sort episodes for me. I've rolled back to 1.6.6.0 and it's still not working - here's the appropriate section from the log: *** Error Report *** Version: 4.8.0.40 Command line: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: C:/Users/Adrian/AppData/Roaming/MediaBrowser-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server Application path: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\system System.MissingMethodException: System.MissingMethodException: Method not found: 'Void SQLitePCL.pretty.IBindParameter.Bind(System.ReadOnlySpan`1<Char>)'. at Emby.AutoOrganize.Data.SqliteExtensions.TryBind(IStatement statement, String name, String value) at Emby.AutoOrganize.Data.SqliteFileOrganizationRepository.<>c__DisplayClass3_0.<SaveResult>b__0(IDatabaseConnection db) at SQLitePCL.pretty.DatabaseConnection.<>c__DisplayClass18_0.<RunInTransaction>b__0(IDatabaseConnection db) at SQLitePCL.pretty.DatabaseConnection.RunInTransaction[T](IDatabaseConnection This, Func`2 f, TransactionMode mode) at SQLitePCL.pretty.DatabaseConnection.RunInTransaction(IDatabaseConnection This, Action`1 action, TransactionMode mode) at Emby.AutoOrganize.Data.SqliteFileOrganizationRepository.SaveResult(FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganizationService.SaveResult(FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.EpisodeFileOrganizer.OrganizeEpisodeFile(String path, TvFileOrganizationOptions options, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.TvFolderOrganizer.Organize(TvFileOrganizationOptions options, CancellationToken cancellationToken, IProgress`1 progress) Source: Emby.AutoOrganize TargetSite: Void TryBind(SQLitePCL.pretty.IStatement, System.String, System.String) HI, please try the AutoOrganize 1.6.7 plugin update and let me know if it resolves the issue. Thanks. 1
AdrianW 1058 Posted August 8, 2023 Posted August 8, 2023 10 hours ago, Luke said: please try the AutoOrganize 1.6.7 plugin update and let me know if it resolves the issue. Thanks. Working now - thanks. 1
Grumpy1 46 Posted August 10, 2023 Posted August 10, 2023 (edited) deleted Edited August 10, 2023 by Grumpy1
