Cheesegeezer 3106 Posted July 2, 2022 Posted July 2, 2022 Just checking in, I’m really looking forward to this being released, @kingy444 are you working on this in the background? Any updates for us 2
Junglejim 385 Posted July 3, 2022 Posted July 3, 2022 16 hours ago, Cheesegeezer said: Just checking in, I’m really looking forward to this being released, @kingy444 are you working on this in the background? Any updates for us Yea me to..! I can't see this part timer doing anything! Just F@#king with people.. SAD! 1
Wheemer 50 Posted July 11, 2022 Posted July 11, 2022 Wow, talk about coming in like a wrecking ball... We love you Chef, your work speaks for itself. I hope we can all look past this towards a greater goal, through cohesive cooperation. Gentle steps...
gillmacca01 220 Posted July 22, 2022 Posted July 22, 2022 Anyone seeing this issue when opening the settings:
slevin7 86 Posted July 22, 2022 Posted July 22, 2022 Yes, unfortunately, everyone. I really hope that chef will take over his plugin again at some point.
gillmacca01 220 Posted July 22, 2022 Posted July 22, 2022 So, I might as well remove it and re-install the one from the plugin catalogue, as I cannot configure anything
chef 3811 Posted July 22, 2022 Author Posted July 22, 2022 (edited) @gillmacca01 Sorry, I have a fix. Emby.AutoOrganize_preprocessing.zip Remove the fileorganizer.db please. Edited July 22, 2022 by chef 2 1
chef 3811 Posted July 22, 2022 Author Posted July 22, 2022 Those SmartMatches are unstable. I dont know exactly why. Also kingy has some UI changes coming. It uses a grid layout instead of flex. As for the smart matches, I'll continue to look at the code and see where things go wrong. In the meantime, there are so e new options there if you are going to point watched folders directly to a folder which contains compressed recording. In that case, switching the toggle will allow you to choose a preprocessing folder, which will handle your recordings automatically. If you don't toggle this option on, then you'd most likely have another application preprocessing your recording. Cool! 2
AdrianW 1058 Posted July 26, 2022 Posted July 26, 2022 @chef Thanks for getting Auto Organise working again. One thing I'd like to see fixed is making it only copy one file at a time. I just organised 5 episodes of the same series and all 5 files were copied simultaneously, that has to be really bad for both copy performance and file fragmentation on the destination. 1
chef 3811 Posted July 26, 2022 Author Posted July 26, 2022 5 hours ago, AdrianW said: @chef Thanks for getting Auto Organise working again. One thing I'd like to see fixed is making it only copy one file at a time. I just organised 5 episodes of the same series and all 5 files were copied simultaneously, that has to be really bad for both copy performance and file fragmentation on the destination. I was able to do this. It ties up the thread. This causes the files to copy one after another, and stops any asynchronous attempts. Should that be an option in the setting though? Or, if the eligible file count is small just copy them over asynchronously, but if the file count is high do them in order?
chef 3811 Posted July 26, 2022 Author Posted July 26, 2022 (edited) This: FileOrganizationResult result; if (eligibleFiles.Count > 3) //This could be an option in settings { result = organizer.OrganizeFile(false, file.FullName, options, cancellationToken).Result; //<== "Result" will stop multiple organizations at once, and process one at a time. Yes, calling "Result". So sue me. } else { result = await organizer.OrganizeFile(false, file.FullName, options, cancellationToken); //<== Process them all at once, or when TPL starts them. } Edited July 26, 2022 by chef
chef 3811 Posted July 26, 2022 Author Posted July 26, 2022 Let's see what @kingy444 has next. He has been working diligently. 1
Cheesegeezer 3106 Posted July 26, 2022 Posted July 26, 2022 35 minutes ago, chef said: Let's see what @kingy444 has next. He has been working diligently. psssssst Chef..... check your pm's
Flux02400 4 Posted August 4, 2022 Posted August 4, 2022 Hi, just for report a little bug, the option "Create sub-directory per Movie" have an issue, it always create folder no matter you uncheck the box. thx 1
Cthalpa 11 Posted August 8, 2022 Posted August 8, 2022 On 7/22/2022 at 3:36 PM, chef said: Sorry, I have a fix. Emby.AutoOrganize_preprocessing.zip 247.69 kB · 19 downloads Remove the fileorganizer.db please. Saving settings is not working...
chef 3811 Posted August 8, 2022 Author Posted August 8, 2022 3 hours ago, Cthalpa said: Saving settings is not working... Hi! Can I see a log? You can pm me it if you want. Did you completely shut down the server, remove the fileorganizer.db and then restart the server?
chef 3811 Posted August 9, 2022 Author Posted August 9, 2022 (edited) On 8/4/2022 at 9:09 AM, Flux02400 said: Hi, just for report a little bug, the option "Create sub-directory per Movie" have an issue, it always create folder no matter you uncheck the box. thx I have fixed this here: Emby.AutoOrganize_v1.6.41.35.zip Also: While bulk organizing, items might get stuck in a 'checking' state. If this happens simply press the "Re-process" button to do just that. Fixed While organizing with corrections a movie parent folder was always created. Now it honors the settings. Searching queries the database instead of what is loaded on screen. visual enhancements for action buttons. Other small bug fixes. Edited August 9, 2022 by chef 3
neik 874 Posted August 9, 2022 Posted August 9, 2022 chef, do we need to remove the existing database with this update?
slevin7 86 Posted August 9, 2022 Posted August 9, 2022 1 hour ago, neik said: chef, do we need to remove the existing database with this update? It doesn't look to me like you need to remove the DB. If it does, I've done something wrong apparently. 1
neik 874 Posted August 9, 2022 Posted August 9, 2022 FYI... I had to remove the database but was also on an older version. 1
Flux02400 4 Posted August 9, 2022 Posted August 9, 2022 8 hours ago, chef said: I have fixed this here: Emby.AutoOrganize_v1.6.41.35.zip 247.95 kB · 3 downloads Also: While bulk organizing, items might get stuck in a 'checking' state. If this happens simply press the "Re-process" button to do just that. Fixed While organizing with corrections a movie parent folder was always created. Now it honors the settings. Searching queries the database instead of what is loaded on screen. visual enhancements for action buttons. Other small bug fixes. Same issue: (i have copy the updated dll and delete fileorganization.db) When "create folder" is unchecked and folder pattern is set then it "auto organize" automatically but create folder. <CreateMovieInFolder>false</CreateMovieInFolder> <MovieFolderPattern>%mn</MovieFolderPattern> When "create folder" in unchecked and folder pattern is blank then it can't "auto organize" you have to do it manualy but it works and don't create folder <CreateMovieInFolder>false</CreateMovieInFolder> <MovieFolderPattern /> thx 1
chef 3811 Posted August 9, 2022 Author Posted August 9, 2022 3 hours ago, Flux02400 said: Same issue: (i have copy the updated dll and delete fileorganization.db) When "create folder" is unchecked and folder pattern is set then it "auto organize" automatically but create folder. <CreateMovieInFolder>false</CreateMovieInFolder> <MovieFolderPattern>%mn</MovieFolderPattern> When "create folder" in unchecked and folder pattern is blank then it can't "auto organize" you have to do it manualy but it works and don't create folder <CreateMovieInFolder>false</CreateMovieInFolder> <MovieFolderPattern /> thx wow, tricky bug you found there. It was hiding in a condition which ignored options. You'd have to know how the entire solution works to actually spot it. Interestingly enough it has opened another bug which will mark an "Existing Item" as "New Edition" if you change that option after initially sorting an item, and attempting to re-process it. So... I will look at that, however this should fix the movie folder options bug here: Emby.AutoOrganize_v1.6.41.36.zip Good work finding this. Thank you. 1
chef 3811 Posted August 9, 2022 Author Posted August 9, 2022 16 hours ago, Cthalpa said: Saving settings is not working... ... and how did you fair with getting this up and running?
Flux02400 4 Posted August 10, 2022 Posted August 10, 2022 Hi, Another problem (seems due to charsets french) the é,è,à,â etc are not transfert properly: "Astérix et Obélix Mission Clépâtre (2002)" become "Ast Rix Et Ob Lix Mission Cl Op Tre (2002)" And Cthalpa is right, saving settings are not working well, example: for movie pattern name and smart autodetect movie (i'm not testing shows for now), modify are not saving. Personaly, i edit manually autoorganize.xml for those two settings and continue testing thx,
