chef 3811 Posted March 23, 2024 Author Posted March 23, 2024 Actually, I'm going to rename the database to add plus to it. That way there is not any conflicting issues with auto organize. 1
chef 3811 Posted March 23, 2024 Author Posted March 23, 2024 Renaming languages in file names will most likely only work if the name is available from the provider in that language.
AdminArea51 0 Posted March 24, 2024 Posted March 24, 2024 14 hours ago, chef said: Okay. Let me take a look after work. It might be the database file. Cool. Thanks.
chef 3811 Posted March 24, 2024 Author Posted March 24, 2024 (edited) 16 hours ago, User2808 said: Sry, but what does that mean? Inorder to rename files in other languages, we would first have to use the providers to find the proper naming (the plugin already does this). Then we would have to switch languages in the provider API, and grab the name. If the providers doesn't have the metadata in the API in the other language (ie. German), then we wouldn't be able to rename the file. Edited March 24, 2024 by chef
chef 3811 Posted March 25, 2024 Author Posted March 25, 2024 found the language specific code for the plugin. Took a minute to read through everything again. There is no way to go back and rename files, but we can try to rename future files. 1
phoenix4 1 Posted March 26, 2024 Posted March 26, 2024 On 24/03/2024 at 01:34, chef said: Okay. Let me take a look after work. It might be the database file. Hi Chef, did you have any luck with this? (Emby 4.8.3.0)
chef 3811 Posted March 26, 2024 Author Posted March 26, 2024 (edited) 7 hours ago, phoenix4 said: Hi Chef, did you have any luck with this? (Emby 4.8.3.0) If the issue is indeed the database, then I have been successful in creating a new database file that plus will use. However, moving to the new version will mean starting auto organize data from scratch. If you were like me and kept a tally of all the sorted media, it will be gone. and will have to be started again from scratch. This new database file should fix the issue. Just running last minutes checks this afternoon to make sure no issues are there. Edited March 26, 2024 by chef
chef 3811 Posted March 26, 2024 Author Posted March 26, 2024 Languages on the other hand is a bit more tricky. Still looking I to it. 1
phoenix4 1 Posted March 26, 2024 Posted March 26, 2024 6 hours ago, chef said: If the issue is indeed the database, then I have been successful in creating a new database file that plus will use. However, moving to the new version will mean starting auto organize data from scratch. If you were like me and kept a tally of all the sorted media, it will be gone. and will have to be started again from scratch. Thanks chef! The history doesn't worry me personally. With its own database now does that mean it's less likely to break with new Emby versions?
Michiplatz 3 Posted April 9, 2024 Posted April 9, 2024 Hello, I've been working on emby for 2 hours now, setting everything up and would also like to try this plugin, but how do I install it? I can't find it in the emby library and I can't find a way to install the zip manually. Do I have to do this via console or how, sorry I'm totally new here and don't quite understand it yet
chef 3811 Posted April 11, 2024 Author Posted April 11, 2024 On 4/9/2024 at 10:31 AM, Michiplatz said: Hello, I've been working on emby for 2 hours now, setting everything up and would also like to try this plugin, but how do I install it? I can't find it in the emby library and I can't find a way to install the zip manually. Do I have to do this via console or how, sorry I'm totally new here and don't quite understand it yet I'll post a new dll here shortly for you.
User2808 3 Posted April 22, 2024 Posted April 22, 2024 (edited) On 3/26/2024 at 5:43 PM, chef said: Languages on the other hand is a bit more tricky. Still looking I to it. Hello again! Are there any updates or news about this topic? Sincerely Edited April 22, 2024 by User2808
User2808 3 Posted May 30, 2024 Posted May 30, 2024 It's certainly not meant to be annoying, but is there any movement on the matter? Alternatively, I'll have to put up with the English titles, which is fine.
chef 3811 Posted May 30, 2024 Author Posted May 30, 2024 Hey, I had to let this plugin go. There are other applications that can handle sorting media better then this version. Unfortunately, there just wasn't enough interest in it from the community to keep it updated. Sorry man. 1
Luke 42252 Posted May 30, 2024 Posted May 30, 2024 Thanks for the update chef. I think the Emby auto organize plugin is pretty robust anyway.
phoenix4 1 Posted June 9, 2024 Posted June 9, 2024 Sad to see this one die. Thanks for your work as always Chef.
ashok863 0 Posted November 24, 2025 Posted November 24, 2025 (edited) On 23/03/2024 at 10:47, chef said: Actually, I'm going to rename the database to add plus to it. That way there is not any conflicting issues with auto organize. Suggest the app has a different name as well, it seems to overlap the emby version. Also suggest it be added to the Emby plugin catalog for easy install/uninstall. Or is there a way to add 3rd party library to the catalog? Edited November 24, 2025 by ashok863
Luke 42252 Posted November 24, 2025 Posted November 24, 2025 1 hour ago, ashok863 said: Suggest the app has a different name as well, it seems to overlap the emby version. Also suggest it be added to the Emby plugin catalog for easy install/uninstall. Or is there a way to add 3rd party library to the catalog? I think this one is obsolete now anyway. The main auto organize plugin has gotten numerous updates since this was introduced.
