GOTCHA_SA 8 Posted January 31, 2024 Posted January 31, 2024 Hi for the Beta Server Auto Organize version 1.7.0.0 For TV and Movies renaming is it possible (or is there any plans) to add %res to the supported Patterns? This function is available in the version 1.6.41.43 that Chef created. screenshot below Thanks in advance
GOTCHA_SA 8 Posted February 2, 2024 Posted February 2, 2024 On 31/01/2024 at 19:38, GOTCHA_SA said: Hi for the Beta Server Auto Organize version 1.7.0.0 For TV and Movies renaming is it possible (or is there any plans) to add %res to the supported Patterns? This function is available in the version 1.6.41.43 that Chef created. screenshot below Thanks in advance @chef anything you can do on this one?
Luke 42252 Posted February 2, 2024 Posted February 2, 2024 26 minutes ago, GOTCHA_SA said: @chef anything you can do on this one? Currently that doesn’t get parsed from the file name, so that would have to be built first.
GOTCHA_SA 8 Posted February 2, 2024 Posted February 2, 2024 24 minutes ago, Luke said: Currently that doesn’t get parsed from the file name, so that would have to be built first. Many thanks @Lukefor the response, is this something that could be added to the AutoOrganize plugin. For me I use the below format for all my Movies and TV Series as I like to keep all the different resolution versions within the same folder: Tv Shows Series Name S01E04 - resolution.mkv (%sn S%0sE%0e - %res.%ext) Movies: Movie Name (2017) - resolution.mkv (%mn (%my) - %res.%ext) Appreciate anything you can do 1
mauricek 0 Posted March 12, 2024 Posted March 12, 2024 Hi there, i've been using Auto organize plus for a long time now. The latest emby Update to version 4.8.3 broke it. I wanted to update my version now but all the uploads here are unavailiable. Will it be released to the officeial plugins at some point replacing the normal auto-organize? Is there still a download from a version that works with 4.8.3?
chef 3811 Posted March 12, 2024 Author Posted March 12, 2024 (edited) @mauricek you can use this version here to continue using AO+ Emby.AutoOrganize_1.9.41.44.zip Edited March 12, 2024 by chef 2
Kyrunner 86 Posted March 12, 2024 Posted March 12, 2024 Can someone explain to me what the purpose of this plugin does? I installed the plugin from the official plugins not this one I can’t find any documentation on its purpose. From what I can tell you drop a movie into a folder it watches and it rename it and move it someplace else on the server. Doesn’t seem to do much more then me renaming and putting the file where I want it. What am I missing or better yet can someone point me to the wiki on the plugin
AdrianW 1058 Posted March 12, 2024 Posted March 12, 2024 40 minutes ago, Kyrunner said: an someone explain to me what the purpose of this plugin does? For me the main purpose is organising TV episodes. I can drop show.name.S02E03.random.tags.mkv into a folder and the plugin will rename it to show name S01E03 Episode Title.mkv and move it to the correct show/season folder in whatever library it needs to go into.
Kyrunner 86 Posted March 12, 2024 Posted March 12, 2024 41 minutes ago, AdrianW said: For me the main purpose is organising TV episodes. I can drop show.name.S02E03.random.tags.mkv into a folder and the plugin will rename it to show name S01E03 Episode Title.mkv and move it to the correct show/season folder in whatever library it needs to go into. How is this different from using filebot? if I have to rename the episode or movie isn’t the work already done. I just can’t get my head around this plugin. Now if I could drop in say title.mkv and somehow it could find and label that would be a game changer
Neminem 1625 Posted March 12, 2024 Posted March 12, 2024 It's there for lazy people, than don't want to do the work them self. Just my guess ¯\_(ツ)_/¯
chef 3811 Posted March 12, 2024 Author Posted March 12, 2024 21 minutes ago, jaycedk said: It's there for lazy people, than don't want to do the work them self. Just my guess ¯\_(ツ)_/¯
chef 3811 Posted March 12, 2024 Author Posted March 12, 2024 4 hours ago, Kyrunner said: How is this different from using filebot? if I have to rename the episode or movie isn’t the work already done. I just can’t get my head around this plugin. Now if I could drop in say title.mkv and somehow it could find and label that would be a game changer describe what you mean by 'label'.
Kyrunner 86 Posted March 12, 2024 Posted March 12, 2024 19 minutes ago, chef said: describe what you mean by 'label'. Rename the file
AdrianW 1058 Posted March 13, 2024 Posted March 13, 2024 22 hours ago, Kyrunner said: if I have to rename the episode or movie isn’t the work already done. But the point is that the plugin does the renaming (and moving) for you. No manual renaming required. 1
Kyrunner 86 Posted March 13, 2024 Posted March 13, 2024 39 minutes ago, AdrianW said: But the point is that the plugin does the renaming (and moving) for you. No manual renaming required. I’ve never seen this happen. If you drop say lone survivortc03.mkv it won’t recognize it and you will have to manually rename it with the year. This is my point I have name correctly and put the year in and the title then I will move it. But with out it named correctly it does nothing. Unless I’m doing something wrong or not using it correctly. Would love to see a wiki or documentation on the plugin
AdrianW 1058 Posted March 14, 2024 Posted March 14, 2024 On 13/03/2024 at 23:51, Kyrunner said: I’ve never seen this happen. Perhaps you're only collecting reality shows with weird naming conventions. For the vast majority of TV shows the names start out in the format show.name.SnnEnn.various.scene.tags.mkv - there needs to be a show name, season number and episode number somewhere in the name. 1
chef 3811 Posted March 14, 2024 Author Posted March 14, 2024 On 3/12/2024 at 4:26 PM, Kyrunner said: Rename the file Right, so this plugin will rename the file it find for you. If you rip a disc, the application that ripped the disc will most likely name it a certain way. (Yes, and as an aside I realize that the Internet also has naming convention for media) This plugin will find those files and rename them and then copy them into you emby library. Specifically, with the plus version, if the original file is compressed, it will locate it, and decompress it before organizing into the emby library. The plus version does have some extra name conventions available as well. Let me know if I answered your original question or not. If there is a functionality that can be added to the plugin, I'm definitely interested in it. Thanks again. Chef.
chef 3811 Posted March 15, 2024 Author Posted March 15, 2024 On 3/13/2024 at 11:51 AM, Kyrunner said: I’ve never seen this happen. If you drop say lone survivortc03.mkv it won’t recognize it and you will have to manually rename it with the year. This is my point I have name correctly and put the year in and the title then I will move it. But with out it named correctly it does nothing. Unless I’m doing something wrong or not using it correctly. Would love to see a wiki or documentation on the plugin in this case, you may have to use the "Smart Matches" options available under the smart matches tab. "lone survivortc03.mkv" is not necessarily a typical naming convention, and therefore, most likely would get missed. Something like: lone.survivor.S03E01.tc.mkv might be a more conventional scheme. However, if the naming scheme you have shown above is from a specific application (and it is a convention that may show up often), I'll add that to the plugin. Let me know.
Riezel 34 Posted March 17, 2024 Posted March 17, 2024 (edited) On 3/12/2024 at 8:41 PM, chef said: @mauricek you can use this version here to continue using AO+ Emby.AutoOrganize_1.9.41.44.zip 247.3 kB · 6 downloads Hello chef, recently i started trying your plugins again, is there any way to add mixed content directory in root selection ? or even automatically select root (based on registered series path), or is this root is needed for custom smart match ? also is it possible to create custom smart match for series ? Edited March 17, 2024 by Riezel 1
chef 3811 Posted March 18, 2024 Author Posted March 18, 2024 22 hours ago, Riezel said: Hello chef, recently i started trying your plugins again, is there any way to add mixed content directory in root selection ? or even automatically select root (based on registered series path), or is this root is needed for custom smart match ? also is it possible to create custom smart match for series ? Let me look into this. I think this should be an easy addition. 1
gihayes 47 Posted March 19, 2024 Posted March 19, 2024 Hi Chef, I recently loaded Auto-Organize PLUS after upgrading to the latest Emby stable version and I am getting a fail every time it runs. I tried uninstalling and re-installing it but am still getting the error. Any assistance would be appreciated. Thanks. embyserver.txt
User2808 3 Posted March 20, 2024 Posted March 20, 2024 Hello everyone! Is there a way to rename the files to another language? I would like to continue to have my movie titles in German. With kind regards,
chef 3811 Posted March 23, 2024 Author Posted March 23, 2024 On 3/20/2024 at 1:47 PM, User2808 said: Hello everyone! Is there a way to rename the files to another language? I would like to continue to have my movie titles in German. With kind regards, Perhaps there is yes. But it might take some looking into. 1
chef 3811 Posted March 23, 2024 Author Posted March 23, 2024 On 3/19/2024 at 12:00 AM, gihayes said: Hi Chef, I recently loaded Auto-Organize PLUS after upgrading to the latest Emby stable version and I am getting a fail every time it runs. I tried uninstalling and re-installing it but am still getting the error. Any assistance would be appreciated. Thanks. embyserver.txt 433.65 kB · 2 downloads Okay. Let me take a look after work. It might be the database file.
