Dmunozv04 1 Posted July 1, 2022 Posted July 1, 2022 I am also experiencing this issue on the latest TestFlight build
Wolfen420 8 Posted July 2, 2022 Posted July 2, 2022 44 minutes ago, Luke said: Hi, have you tried the 1.6.0 Emby app update? If that question is directed at me then yes. It's already on 1.60(1) it says.
SamES 1084 Posted July 4, 2022 Posted July 4, 2022 @brogen,@jpw007, @Skyfay, @Wolfen420, can you please confirm OS/type version Server app version Whether this issue is with local or remote playback ATV app version Thanks
Wolfen420 8 Posted July 4, 2022 Posted July 4, 2022 23 minutes ago, SamES said: @brogen,@jpw007, @Skyfay, @Wolfen420, can you please confirm OS/type version Server app version Whether this issue is with local or remote playback ATV app version Thanks DSM 6.2.4-25556 Update 6 Emby Server: 4.7.5.0 Local playback 1.6.0(1) 1
Skyfay 19 Posted July 4, 2022 Posted July 4, 2022 1 hour ago, SamES said: @brogen,@jpw007, @Skyfay, @Wolfen420, can you please confirm OS/type version Server app version Whether this issue is with local or remote playback ATV app version Thanks Docker on a Linux Machine Emby Server: 4.7.5.0 Remote playback i have to look at home but should be latest 1
jpw007 1 Posted July 4, 2022 Posted July 4, 2022 (edited) 11 hours ago, SamES said: @brogen,@jpw007, @Skyfay, @Wolfen420, can you please confirm OS/type version Server app version Whether this issue is with local or remote playback ATV app version Thanks OS/type version: Docker via Unraid Server app version: 4.6.7.0 (last version that has worked and now been running since 22 June), and all releases up to and including 4.7.2.0 have had issues. Have not tried newer than that as of yet due to time constraints and needing access to my media for school holidays. Whether this issue is with local or remote playback: Local. Don't use remote so unsure if it works. ATV app version: Latest (i think it force updates so always running latest release at any one time) Edited July 4, 2022 by jpw007
Luke 42241 Posted July 5, 2022 Posted July 5, 2022 If someone could provide access to their server for testing, please send me a PM with the server url, username, password, and the name of the video that we should test. That would be extremely helpful. Thanks guys.
Skyfay 19 Posted July 5, 2022 Posted July 5, 2022 2 minutes ago, Luke said: If someone could provide access to their server for testing, please send me a PM with the server url, username, password, and the name of the video that we should test. That would be extremely helpful. Thanks guys. Do you need an Admin User for testing?
Luke 42241 Posted July 5, 2022 Posted July 5, 2022 22 minutes ago, Skyfay said: Do you need an Admin User for testing? No. Just a user with access to a video exhibiting the problem.
Skyfay 19 Posted July 5, 2022 Posted July 5, 2022 (edited) On 7/5/2022 at 7:33 AM, Luke said: No. Just a user with access to a video exhibiting the problem. Okay. I sent you the information... Edited July 7, 2022 by Skyfay
Wolfen420 8 Posted July 7, 2022 Posted July 7, 2022 @SamESJust curious if there are any updates on this. Any new discoveries or any support we can provide to help resolve this?
SamES 1084 Posted July 7, 2022 Posted July 7, 2022 34 minutes ago, Wolfen420 said: @SamESJust curious if there are any updates on this. Any new discoveries or any support we can provide to help resolve this? Just testing this now... 1
SamES 1084 Posted July 7, 2022 Posted July 7, 2022 1 hour ago, Wolfen420 said: @SamESJust curious if there are any updates on this. Any new discoveries or any support we can provide to help resolve this? From the server, can you try refreshing the metadata for a file you know doesn't play? Give it a minute, then try playing it.
Wolfen420 8 Posted July 7, 2022 Posted July 7, 2022 35 minutes ago, SamES said: From the server, can you try refreshing the metadata for a file you know doesn't play? Give it a minute, then try playing it. I have confirmed with two separate files that refreshing the metadata (default options) indeed resolves this problem. I could play both of them with the MPV enabled.
Skyfay 19 Posted July 7, 2022 Posted July 7, 2022 1 minute ago, Wolfen420 said: I have confirmed with two separate files that refreshing the metadata (default options) indeed resolves this problem. I could play both of them with the MPV enabled. So is that the solution? Refresh all metadata?
Wolfen420 8 Posted July 7, 2022 Posted July 7, 2022 2 minutes ago, Skyfay said: So is that the solution? Refresh all metadata? I don't know. It worked for the two files I tried it on. They did not play with MPV off. I refreshed one file. Tried with MPV on. It worked. To check again I checked next file, it did not play video, but only audio (with spinning wheel on video as usual), refreshed its metadata... played fine. Signs are pointing to it being the fix for me at least. 1
Skyfay 19 Posted July 7, 2022 Posted July 7, 2022 1 minute ago, Wolfen420 said: I don't know. It worked for the two files I tried it on. They did not play with MPV off. I refreshed one file. Tried with MPV on. It worked. To check again I checked next file, it did not play video, but only audio (with spinning wheel on video as usual), refreshed its metadata... played fine. Signs are pointing to it being the fix for me at least. What do you mean by MPV?
Wolfen420 8 Posted July 7, 2022 Posted July 7, 2022 (edited) 4 minutes ago, Skyfay said: What do you mean by MPV? In the settings menu for playback there is an option for use MPV. If you disable that it lets you play some of the files, but it's not fully reliable. I think it's a player. Anyhow, it's more reliable/solid when enabled. But it wasn't working. If you read the previous comments in this thread people found if you turn it off it works sometimes. In short. You want MPV on. Edited July 7, 2022 by Wolfen420 1
Skyfay 19 Posted July 7, 2022 Posted July 7, 2022 1 minute ago, Wolfen420 said: In the settings menu for playback there is an option for use MPV. If you disable that it lets you play some of the files, but it's not fully reliable. I think it's a player. Anyhow, it's more reliable/solid when enabled. But it wasn't working. If you read the previous comments in this thread people found if you turn it off it works sometimes. Ah got you. Thanks for this information! I try to refreshing all my metadata i think this could take some time haha
Wolfen420 8 Posted July 7, 2022 Posted July 7, 2022 Just now, Skyfay said: Ah got you. Thanks for this information! I try to refreshing all my metadata i think this could take some time haha Right there with you haha. It's hanging out at 90% for me still on just the TV Shows. I hope this fixes all of them. You should of just tried it on a single file to see if that solved your problem first.
Skyfay 19 Posted July 7, 2022 Posted July 7, 2022 2 minutes ago, Wolfen420 said: Right there with you haha. It's hanging out at 90% for me still on just the TV Shows. I hope this fixes all of them. You should of just tried it on a single file to see if that solved your problem first. Nah, i trust you The problem is i got a special setup and this takes loot of time and i got lots of series so this could take some hours I think stuck at 90% is normal.
Wolfen420 8 Posted July 7, 2022 Posted July 7, 2022 Just now, Skyfay said: Nah, i trust you The problem is i got a special setup and this takes loot of time and i got lots of series so this could take some hours I think stuck at 90% is normal. I am around 30ish terabytes of videos.
Skyfay 19 Posted July 7, 2022 Posted July 7, 2022 1 minute ago, Wolfen420 said: I am around 30ish terabytes of videos. I got 53 TB
Wolfen420 8 Posted July 7, 2022 Posted July 7, 2022 Just now, Skyfay said: I got 53 TB Guess we report our findings tomorrow haha. 1
